I want my phone to ring longer before it goes to voice mail
Select the model of your Uniden DECT 6.0 system from the list beginning at http://www.uniden.com/scat/dectphones_mnl to download the manual.
SOURCE: I have a Uniden DECT6.0
Hi.
Setting the Number of Rings
The
ring time setting allows you to set the number of rings the caller
hears before your answering system plays the outgoing message. You can
set the ring time to answer after two, four, or six rings. If you enable
the Toll Saver (TS) setting, the answering system picks up after two
rings if you have new messages, and after four rings if there are
none.
This way, if you make a long distance call to check your messages, you
can hang up after the third ring to avoid long distance billing charges.
post a comment for further assistance.
Thank you for using fixya have a nice day:-)
SOURCE: i lost my manual on Uniden dect1580 phone. it's
please download your manual here in the list: http://telephones.att.com/telephones_ui/support/dsp_manuals_list.cfm
SOURCE: Uniden Dect1560 - For incoming
Your model is a phone only, without an answering machine built in. This means that voicemail is provided by your phone service on your line, and that's where you need to adjust the rings before it picks up. The phone itself has nothing to do with it.
You may have to call your service provider for setup instructions because not all systems are the same, but here's how it usually works. Pick up your phone and call your own number to reach your voicemail. When your message starts, press the * button and the system will ask for your pass code (just like when you call to get your messages). Follow the voice prompts to reach the main menu, then mailbox settings, where you'll be able to change the ring count.
If these steps don't work for you, ask your service provider what you need to do.
Testimonial: "Thank you. Great answer."
