You may have a bad power supply.
You would be better off picking up a small APC or UPS and have all your computer devices running thru.
It is common that after a power interruption the modem must reset to regain it lost signal
Try restarting the modem by either turning off the power button, or plugging out the modem power.
If the internet still frequently disconnects, it is most likely your ISP's (internet service provider) problem. Call them up with this issue, and they should either re-activate your internet for you, or give you a replacement modem for free.
Hope this helps, please rate and leave a comment ^_^
you can't.
when the item name as modem/router. it means the main function is modem with added router function.
you can't connect 2 router/modem together. both need access to the internet and IPS for it function correctly.
however, you can connect 1 modem and one router.
The 5360 is techncially a bridge, not a modem, so it doesn't require software drivers for installation and operation. There is a 5360 firmware upgrade, but it should only be used in certain situations -- see Related Articles at right for further information.
Note that DSL and cable bridges are often called "modems" because that is the familiar term for a device that connects the residential user to the ISP.
jab follow the step below to access your DSL, the ip given is a default ip from the factory.
pls reset the DSL before you continue(press and hold for 4-6 seconds until the power button blinks red)
Connect a computer to the modem. Turn on modem Turn on computer Use a browser to open http://192.168.0.1 Click on Advanced. (you then have lots of things to look at)
Yes. thanks.
