SOURCE: Kenmore 80 series Dryer: Door Light stays on and wont start
Check your door switch actuator part number 691581
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Easy fix. I had the same problem on mine. You need access to the back. Remove back cover. Look at bottom left, you will see two blue wires going to a white plastic item next to one of the thermal sensors. This white plastic piece is a fuse, or fusible link if you like. I'm not sure what the rating is, but you can take the old one to a parts store. They can match it. Now, why did it blow? Well, if the dryer is old, it could be just worn out. But more than likely, one of your 230 volt lines has degraded due to a bad connection, thus drawing more amps, thus blowing the fuse. Look at where the power cord comes in at. Is there any discoloration or oxidation at the terminals? If so, replace the power cord at this time, and try to clean up the terminals as best you can. Also, at this time, you probably better take a look at the lint collector duct running along the left side down the back. It's probably so clogged with lint that your dryer does't dry as fast anymore, and air flow from the exhaust is restricted. Take the duct off and clean it out, or blow it out with compressed air. You should be up and running now. Have fun...
SOURCE: Kenmore 80 Series gas dryer starts with heat but very short time
Hello Friend, Your problem is very simple to fix. You're dryer needs a gas valve coil kit. To replace coils just remove front of dryer body and look below drum you will see the gas valve. The valve coils are located on top of valve (two little round black cylinders). It's simple, just remove the two screws from the little metal bracket that holds them down, unplug the wires from them and just lift them straight up off of the valve. Take notice that one has 3 wires and one has 2 wires. Just replace with new coils and plug wires back in and re-fasten metal bracket. Your dryer will run like new. Happy to help, Tim.
SOURCE: can't find kenmore 80 series dryer drum belt
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
If you have to replace your drum belt and if you have a front loading machine.
Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer. Be real careful not to knock any of the wires off of the timer switch. Then remove the top of the dryer.
Remove the front of the machine, this will expose the belt and drum, remove the drum and belt and this will expose the drum rollers, idler arm bracket with pulley, and motor with pulley. Pay attention to the route of the belt, this will come in handy when you go to reinstall the belt and drum.
Sometimes the belt will slip off of the idler arm or motor causing the drum not to turn.
While you have the drum out, I would recommend that you lubricate the drum rollers at the shaft of the roller with a good grade of machine oil like 3 in One oil. This will save you a problem later with the rollers getting noisy, also check your drum rollers for flat spots, if they have flat spots on them this will cause a noise like a thumping type noise. You will need to replace the drum rollers if they have flat spots on them.
I will include these two websites for parts and further help:
http://www.partselect.com/
http://www.appliancepartspros.com/index.aspx
Both also have chat assistance 24/7.
Also for a manual I will include this website:
http://www.applianceaid.com/
Good luck,
I hope this helps
Testimonial: "many thanks... sounds like a lot of work unlike my old dryer"
SOURCE: Hello, I've got a Kenmore 80 series dryer Model:
Check for lint clogging first. Pull the unit away from the wall and look to see if there is an excessive build up of lint at or near the discharge vent or into the vent line. Clean as needed. If it's really clogged you may have to remove the back cover.
If no joy, then check for a bad thermostat. There should be two. They are located on the discharge vent near the dryer exhaust blower. You will have to remove the back cover of the dryer to get to them. Check the stats for continuity. MAKE SURE the power is off before working on the dryer.
It's much more likely to be on of the two items listed above, but if the dryer isn't clogged and the stats are both good, check the heating element.
The
Kenmore 80 Series of dryers are consumer grade dryers for home use. As
with most home appliances, the Kenmore 80 series dryers will
occasionally not work as intended. If a problem occurs with your dryer,
however, you do not necessarily need it serviced by a technician. You
can attempt to troubleshoot and fix any problems with your dryer before
contacting a technician.
