Question about Kenmore 80809 Microwave Oven
Kenmore microhood model 665.62612200
The control panel lights up and the clock and timers work but nothing else works. no fan blower no lights underneath no heat.
  • Kenmore Master
  • 9,179 Answers
This is usually caused by either a bad door switch, a loose door switch mount, or a problem on the control panel.
Even though a door switch clicks, it may still be bad inside.
Door switches are most often damaged by opening the door while it's cooking (instead of pressing Stop / Clear first) or food
/ grease debris in the switch.
If you or a friend decide to look into it, we have critical information on safety, disassembly and door switches at our site, linked here on Fixya: http://tinyurl.com/yzjozk
It's also possible there may be a problem on the circuit board, which we repair nationwide.
Posted on Nov 05, 2007
Microwave has power, but nothing works.
The door switches are more than likely the problem, one or two will need to be replaced, I recommend a professional.
Mar 18, 2012 | Panasonic Microwave Ovens
Kenmore Microwave Oven, Model#66568680891
you should change the touch panel and or the control module.check to make sure the power supplied is correct and all connections to the board are all secure.
Feb 24, 2010 | Microwave Ovens
JVM1190 wont cook
You have a blown actuator. This is the device that creates the microwaves that cook the food. The cost of one of these will be as much as a new unit.
Nov 09, 2008 | GE JVM1190 Microwave Oven
Kenmore Microhood 401.80089 - L SE L error
The 401 model prefix means it's actually made by Samsung.
On some Samsung models, there is an odd SE error message that seems to be vexing a lot of people.
It's probably a sensor going bad, or maybe scrambled code in the microprocessor, but it's odd.
There is one discussion of it here.
I hate to say it, but since it's a Kenmore brand, you're going to have to call Sears for service.
You can find them at http://www.sears.com
I really hope they can help you.
We're happy to help and we appreciate your thoughtful rating of our answer.
Jun 07, 2008 | Kenmore Microwave Ovens
Kenmore microhood model 721.80833500
our tray that goes around and back and forth jumps the tracks and stops and turns the other way I can put it back on track before it makes a round it jumps the tracks again and starts going the other way is there a part that need replaced
Jan 13, 2008 | Kenmore 80809 Microwave Oven
Troubleshoot why light underneath doesn't work on kenmore 62644 microhood
We see this a lot. The problem is on the control panel, which we regularly repair nationwide for $39.95 postpaid.
We see this a lot. This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
This can often also affect the exhaust fan operation, too. The lights and fan can be inoperable or stuck on too.
Details of our service and critical safety information and disassembly information is at our site, linked here on Fixya:
Nov 28, 2007 | Kenmore 62642 / 62644 / 62649 Microwave...
Help!! I was cleaning my microhood
Sounds like you will either need a new membrane, or pcb.
Jun 28, 2007 | Kenmore 80809 Microwave Oven
Kenmore microhood
"Microhood" seems to be a slang term for the "microwave hood" (hood fan or exhaust fan) which is normally part of an over-the-range microwave oven or range. But these should be available separately, as I seem to recall. I would contact home centers such as Lowe's, Home Depot (if they still exist), etc., or a local appliance store.
Dec 06, 2006 | Kenmore 62622 Microwave Oven
Kenmore 80809 Microwave Oven Logo
244 people viewed this question
Top Kenmore Microwave Ovens Experts
William Miller
William Miller
Gerry Harvey
Gerry Harvey
Are you a Kenmore Microwave Oven Expert? Answer questions, earn points and help others
