SOURCE: grey lines across the screen
Does this happen on all dvs tapes? If so then it is a problem with the head reader of the cam, but if only one tape, then that tape is either has quite an old recording on it or the tape is damaged.
SOURCE: Playback problem
I've encountered this exact problem a month ago, except cleaning the heads did not fix it. However, I was able to find an alternative solution...
After leaving my camera closed up in a drawer for a few weeks, I decided to take it out and leave it in the sun for 15 minutes, assuming that perhaps the gray bars were a result of moisture damage. The next day (Today, to be exact) I turned my camcorder on, and the gray bars have gone away from playback, as well as the reduced sound quallity it caused.
SOURCE: 5 Grey Horizontal Lines across the screen during play back and distorted sound.
Someone here recommended on another post to put the lense cap on & videotape the blackness in a quiet room for 5-10 mins. I tried this as a last resort & it worked. When I played back the tape, no more skipping or gray lines. I had 4-5 SOLID gray lines with skipping video & audio in between on every tape I put in. I think the person who helped me solve this said that it was a result of the tape alignment going off. My camera is a Canon zr80 digital camcorder. (Called Canon, they had me reset it & then recommended sending it in).
SOURCE: Grey horizontal lines during playback on camcorder
yes change the tape and also use a head cleaning cassette to clean the cam. chaminda from Sri Lanka
