The part that drives the nail came out when the nail fired and drove into the wood also. What do I need to buy to fix it?
You should be able to find parts for your model nailer doing a simple web search. Take out the allen screws on the back of gun, remove the back, inside the chamber you'll find a round metal disc, this is the plunger, the drive pin is attached to the other side, the plunger, and pin is one piece, when you remove it you'll see where the pin has broke off.
SOURCE: A Bostitch F28WW that spontaneously fires a nail when coupling.
When was the last time this tool was serviced? Bostitch makes an Oring kit for this part #N890RK I could not find the price. I would start by looking at the safety to make sure that is moves freely and is not bent. Then I would think about putting new rubber in this tool. First go to Stanleybostitch and navigate into tools and then support to look at a breakdown for this one. It is not that difficult to rebuild, if you do make sure that you put lube on the new orings and take your time rebuilding to ensure that you dont pinch one of the new rings. Hope this helps
SOURCE: Help with Bostitch N60 air nail gun.
If it is a N60FN you will have to install a new trigger valve P/N TVA6. Any Bostitch service center should have them.
SOURCE: Bostitch nail gun loss of pressure, won't fire nail
Hello. I can help you. The nail gun you have uses 18 gauge brads. I would use only original Bostitch 18 gauge.
The one MM of difference you mention is the reason why you do not have the pressure you did have. Get rid of those 31MM brads and get the 18 gauge. Home Depot carries the Bostitch line. I would go there or to homedepot.com
SOURCE: my bostitch 1664fn finish nail gun blows lots of air out exaust
Open the front and clear any jammed nails that are there. Oil the gun, push the drive pin back in if it didn't go back in when the front was off and try again. If there are repeated nail jam issues, try genuine Bostich nails.
