If you unplug an Amana PTAC unit and it freezes what could happen?
I am having massive amounts of freezing and polluted air coming through every part (including the front grill) of my Amana PTAC heater/air conditioner. I had it unplugged and suspect it may have frozen since the Freeze Protection would have not been able to kick in and maybe then cracked. I really need some help with this - we are currently having some very bad pollution and it is really cold and we are just miserable. I do not run the unit, because that makes it worse.
  • Heating & Co... Master
  • 2,410 Answers
If you are not going to run the unit put a large bag over the out door section. The unit will be just fine.
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Posted on Jun 08, 2017
6ya staff
SOURCE:
Anonymous
  • 142 Answers
SOURCE: Amana PTAC PTC093A35AA won't blow heat
The reset button is located behing a panel on the front of the unit that is labeled Heat Reset. If that label is gone then look around, it is a small hole, small enough for a paper clip to fit through.
That being said, I have 137 of these units in one of my hotels and have not had a single one needing to be reset. You probably are going to need a new control board kit. These can be purchased from Amana. They are $130. Make sure that you have pulled the heater coil out and inspected it first. Also, there was a recall years ago where Amana was supposed to contact and send out new voltage switches. These are the round black things that the Brown heater wires connect to on the upper and lower side of the heating coil. You should also try to replace those if you find the coil in good condition. I have had those resolve heating issues. Most of the heating issues were a result of a bad relay on the control board though.
Please remember to rate this fix.
Posted on Feb 12, 2009
oscarn
Oscar Netto
  • 110 Answers
SOURCE: ptac fan keeps blowing
Try setting the fan control to "AUTO" this will cause it to cut out with the compressor.
Posted on Sep 07, 2007
bobotfel
Felizardo Erilla
  • 241 Answers
SOURCE: air conditioner
Turn off unit supply and check the blower wheel inside the indoor unit by rotating it manually by your finger if the blower wheel rotates freely then there is something wrong with your fan motor or fan motor capacitor. But if the blower wheel is not rotating freely try to check the fan motor for lubrication or some bushing dried of and no oil
Posted on Dec 31, 2007
bobotfel
Felizardo Erilla
  • 241 Answers
SOURCE: TRANE PTAC
You need to replace your control board, but if you are can repair it by your self you can change the relay that supply the fan and condenser.
Posted on Jan 15, 2008
kaycee71
Kerry C
  • 37 Answers
SOURCE: It's spitting ice crystals when turned on, and is very noisy.
I'm in a similar situation with a physical neccessity for a/c, year round, even though I live in temperate New Jersey. My husband is an A/C / Refrigeration tech & here's some things you can try to fix your Haier A/C.
1.) Make sure you keep the area where the filter is clean, if you aren't using a filter, you are clogging the air flow much quicker, which can lead to freeze ups.
2.) Due to how shoddy things are made now-a-days & with the storm coming through, you may have a conked out compressor or may have a small refrigeration leak, which can also cause freeze ups.
3.) Make darned sure that the unit is level, if you find it is not, leave your unit off for at least 24 hours for the refrigeration gas & oil in the system to level off.
Sadly, I do not know the model or type of Haier A/C you have & as I'd mentioned, things are no longer made to last like they once were & to get 3 years from a newer model is likely to be the best you can hope for. Haier is fairly decent with wanting to keep up customer morale & if it's a newer unit (younger than 18 months), they may help you to repair it for free or low cost. Good luck with that!
Posted on Aug 28, 2009
Amana ptac is blowing cold air ot with heat on and showing FP code
This indicates FREEZE PROTECTION. Please look up an operator's manual on your particular model. A quick download you will find easily.
Jan 07, 2015 | Amana Heating & Cooling
Amana pth153a35ac
The first 3 answers were from idiots. If a person had read her problem they would understand that it is not a oven / stove, but a PTAC unit that heats and cools a room. This type of unit is what is commonly seen in hotels and motels where the individual heating / cooling system is in each room.
Nov 29, 2013 | Ovens
Hisense reset
The outside vent must be OPEN to allow the appliance to get the needed air. In the heating mode of a heat pump, the outdoor coil becomes the condenser. Open the outside vent!
Nov 25, 2013 | Amana Heating & Cooling
AMANA PTAC NOT COOLING
on most ptac they have electric heat so there is seperate controls for cooling it is possible a contactoer or compacitor
Mar 30, 2013 | Amana Heating & Cooling
My amana ptac is not heating....the code "np" is displayed....how do I correct this...we just installed the unit and know little about operation. Thanks
I don't see this error code in the manual. I do see nP as an error code for Window Switch lockout. I just had this happen to me and they had me reset the control board.
Remove case, flick master switch to OFF for 10 seconds. Press Heat/Cool same time turn switch back on HOLD until off light comes on.
You should be fixed. Just had to do this for my unit. I was playing around with the settings and turned on the window switch option by accident.
Feb 02, 2013 | Amana In Wall Install Kit For Digismart...
Have Ptac units that work fine one minute and 2 hours later just blow warm air.. some that also freeze up the front coils
I think your PTAC is under charge, if the air filter is clean and the evaporator is also clean together with the blower. Check the freon charge and refill if suction pressure is below 50psi and discharge is below 190 psi.
Sep 03, 2011 | Amana Heating & Cooling
Looking for manuel reset on heater amana ptac unit heat won't come on new control board
I dont know about this model but in general electric heat wont have a reset button the heat is controled by a sequencer and each elememt has a safty limit switch incase the sequencer sticks in the on mode here is a link to where you can get more info on this model https://www.fixya.com/support/p51773-amana_ptc153b35aj_air_conditioner
Oct 30, 2009 | Amana PTC153B35AJ Air Conditioner
Ptac not heating
the board or the heater need to be replaced
Dec 23, 2008 | Amana AAC051FRB Air Conditioner
Heating & Cooling Logo
368 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Donni Steen
Marvin
Marvin
