Computers & Internet Logo
A
Anonymous Posted on Jan 18, 2014
Running bios/boot menu through external monitor
I need to re-install Windows 7 by boot menu because i don't know Windows password. The screen is broken and i'm using an external monitor. I need to know the key sequence to run setup from boot menu or the key sequence (if there is one) to enable external monitor on BIOS/Boot menu (tried fn-f4; ctrl-F; f2 to enter bios plus f9 to restore settings plus f10 to save and it didn't work). Tks in advance.
2answers
I have an ASUS A54C, running on Windows 7, and can't remember the password. I can't access BIOS to change the startup options.
Try pressing and holding F2 while powering on. Continue to keep F2 depressed until setup menu comes up.
tip
Retrieve Password on ASUS Eee Pad Tablet
Looking For a Password Recovery Program to Access Your Locked ASUS Netbook? Apple's iPad 2 maybe the hottest thing on the hip-happenin' trendy tablet block, but Asus isn't that behind with its own version, currently dubbed the Eee Pad. Till April 2011, this computer has occupied a considerable market share. In this article, we will learn how to <a href="http://www.windowspasswordsrecovery.com/retrieve-asus-password.htm">retrieve ASUS EPad Password</a>. <br /> <a href="http://www.windowspasswordsrecovery.com/images/knowledge/retrieve-asus-password/asus-eee-pad-tablet-password-big.jpg"><img src="asus-eee-pad-tablet-password.jpg" /></a> What is ASUS Eee PC? Asus Eee PC is a subnotebook/netbook computer line from ASUSTeK Computer Incorporated, and a part of the Asus Eee product family. At the time of its introduction in late 2007, it was noted for its combination of a light weight, Linux operating system, solid-state drive and relatively low cost. Newer models have added the option of Windows operating system and traditional hard disk drives.<br /> The first Eee PC was a milestone in the personal computer business, launching the netbook category of small, low cost laptops. According to Asus, the name Eee derives from "the three Es," an abbreviation of its advertising slogan for the device: "Easy to learn, Easy to work, Easy to play".<br /> Some of ASUS's hot products <b>Eee Pad</b>: Eee Slate EP121, Eee Pad Transformer TF101<br /> <b>Eee PC</b>: Eee PC T91, Eee PC 1000HD<br /> <b>EeeBox PC</b>: EeeBox PC B201, EeeBox PC EB1502<br /> How to Regain Password on ASUS Eee Pad Tablet? There are 2 passwords in an EPad, a bios password, an Operation System password. We will separately discuss the 2 cases.<br /> Bios Password Bios password is setting on the bios config, we can press Del button during loading the PC to enter bios config menu, then remove the bios password. Sometimes, you don't know the bios password, look this guide: "<a href="http://www.blog.windowspasswordsrecovery.com/top-3-methods-to-crack-bios-password/">Top 3 methods to crack bios password!</a>".<br /> <b>Tips</b>: As we know, EPad uses touch screen. We could connect it with a USB keyboard to press Del button. <br /> Operation System Password We can install many OS on an ASUS tablet, for example: Linux, Unix, MAC OS, Windows. Here we discuss only windows. <b>1.</b> Download <a href="http://www.windowspasswordsrecovery.com/downloads/Windows_Password_Recovery_Tool_Ent_Trial.exe"><b>Windows Password Recovery Tool</b></a> (free trial).<br /> <b>2.</b> Install and run it.<br /> <b>3.</b> Create a password reset disk. A CD/DVD disk, or a USB Flash Disk, depend on the locked ASUS PC's support.<br /> <b>4.</b> Boot the locked ASUS computer from the password reset disk. <br /> Note: You may need to config bios setting to set it boot from the password reset disk. The 2 articles can help you.<br /> a. <a href="http://www.windowspasswordsrecovery.com/getting_started/bios.htm">Boot from the CD/DVD-ROM</a><br /> b. <a href="http://www.windowspasswordsrecovery.com/getting_started/bios_usb.htm">Boot from the USB Flash Drive</a><br /> <b>5.</b> On the password recovery Windows, select the user account that you forget its logon password, click "reset" button.<br /> <b>6.</b> Confirm you action, then that user's password will be removed.<br /> <b>7.</b> Disconnect the password reset disk, and reboot your ASUS computer. You will access Windows OS without password ( blank password ).<br /> Finally Get away from the troubles of forgetting ASUS PC Password, no matter it is bios/cmos password or Windows password. <br /> Tips: <b>1.</b> The Windows Password Recovery Tool supports all versions of Windows OS, including Windows 7, Vista, XP, 2000, 2003, 2008. It is popular way of regain your password, even you don't have a password reset disk. <br /> <b>2.</b> Keep in mind that this tool can be only used on your own computer, never try to use it to crack PC password without permission. Otherwise, you will get into trouble by law.<br /> <b>3.</b> You can <b><a href="http://www.windowspasswordsrecovery.com/create-windows-7-password-reset-disk.htm">create a ASUS Eee Pad Password Reset disk</a></b> before you forget password. <br />
on May 23, 2011 • Computers & Internet
tip
Forgot Windows 7 Password?
Many people ask me the question that how to recover their lost Windows 7 Password on my site or Email. I know they urgently need to access Windows 7 for different reasons. they are worry that the Win7 OS would be destroyed and their data would be lost. This is not worried and I will tell you the steps to recover forgotten Windows 7 login password.
Notes: You need a Windows 7 Password Reset disk. If you don't have created it before, you should use the Windows Password Recovery Tool to burn a reset CD/DVD or USB flash drive.
Step 1. Download the Windows Password Recovery ToolGo to the official site of Windows Password Recovery Tool, and download it for free. Install it with default options.
Step 2. Create a Windows 7 Password Reset disk Run this soft, insert a blank cd/dvd or usb flash drive. Follow the step-by-step guide to burn a Windows 7 Password Reset disk. You can burn it to a cd/dvd or USB, it depends on your personal condition. After burning successfully, you get a password reset disk. Now insert this password reset disk into the locked computer which you lost Windows 7 Password.
Step 3. Set the bios config to boot from cd/dvd or usb
  • 1. Start your locked Windows 7 Computer, press Del or F2 button while the computer is initalizing. The initial startup screen may be similar as this image. If you do that, you may see the bios config screen.
  • 2. Go to the boot menu and change bios setting to make it boot from cd/dvd or usb firstly.
3.
Press F10 to save your changes, then restart this computer.
4 . After restart, the computer will automatically load Windows password Recovery Tool and you can start to reset Windows 7 Password. let_me_help_4.jpg
Step4. Recover Windows 7 Password with the password reset disk.
  • 1. Choose the Windows 7 Installation if you have more than one OS in this computer.
  • 2. All Windows 7 users will be listed. Select the user name which you forgot its password, click reset button.
on Apr 03, 2011 • Computers & Internet
Boot hp mini 1151nr laptop bios password
Re Bios Password Reset HP Mini 1000 1151NR
Try going to this site and follow what it says. If this doesn't help, please let me know.
thanks.
tip
How to Boot From A Windows 7 Password Reset Disk?
<span>Forgot Windows 7 password? It seems to be a universal iusse as widespread of Windows 7. To solve this problem, you can either buy a burned Windows password recovery CD on-line or burn such a password recovery disk with<b><a href="http://www.passwordunlocker.com/knowledge/windows-7-password-reset.html">Windows 7 password reset</a></b><span> </span>software. But no matter which method you choose, you have to boot your locked computer from the password recovery disk. However, you will feel frustrated when you have little computer skill. Take these 2 methods as your reference when you encounter the similar problem.<br />Of course, firstly , you need to create a<span> </span><a href="http://www.passwordunlocker.com/knowledge/create-win-7-password-reset-disk.html">Windows 7 password reset disk</a>, and then pay attention on how to boot from the Windows password reset disk .<br /> Method OneInsert a burned Windows 7 password recovery CD in your locked computer boot the locked computer from the CD/DVD as follows:<br /> <ul> <li>1. Turn on or restart the locked computer, watch the screen for a message like "Press to http://www.passwordunlocker.enter SETUP "or something similar. Press this key as soon as you see the message to enter BIOS menu.</li><b>Note</b>: The key pressed to enter BIOS is different based on manufacturers, but F2 or Delete are the most common keys <li>2. Use arrows to choose Boot on the taskbar, select<b><span> </span>Boot Device Priority</b><span> </span>and press Enter.</li> <li>3. Set<span> </span><b>CD ROM</b><span> </span>to the first boot device according to the prompts on the right.</li> <li>4. Press<b><span> </span>F10<span> </span></b>to save and exit BIOS. You computer will restart with the changed BIOS settings</li></ul><br /> Method Two <p>If the method above doesn't work, you can also try to enter Boot Menu to boot the locked computer from the burned CD/DVD as follows:<br /> <ul> <li>1. Insert a Windows 7 password recovery CD in your locked computer.</li> <li>2. Start the locked computer and immediately tap and keep tapping<b><span> </span>F8</b>,<span> </span><b>ESC</b><span> </span>or other keys until the Boot Menu screen appears.</li> <li>3. Select<span> </span><b>CD ROM</b><span> </span>as the first boot device and press Enter. After that, your computer will restart with changed bios settings.</li></ul>PC users can not only set bios password for computer, but also set Windows logon password. If the BIOS is password protected, you need to clear or remove the BIOS password before you can enter BIOS to change boot order.<br />By the way, if you forgot Windows 7 password or Windows 7 password-protected, it is suggested to take Windows password recovery software to create a Windows password reset disk. Take<span> </span><b>Windows Password Unlocker<span> </span></b>for example, it takes you only 4 steps to burn a bootable CD/DVD or USB flash drive for Windows 7 password recovery in 5 minutes.<br /><b>Step 1:</b><span> </span>Download and install<span> </span><b><a href="http://www.passwordunlocker.com/windows-password-recovery.html">Windows Password Unlocker Professional</a></b><span> </span>in any availble PC<br /><b>Step 2:</b><span> </span>Burn a Windows 7 Password Recovery CD/DVD or USB flash drive.<br /><b>Step 3:</b><span> </span>Boot from the burned the Password Recovery CD/DVD or USB flash drive.<br /><b>Step 4:</b><span> </span>Reset Windows 7 password under Windows PE.<br /></span>
on Mar 23, 2011 • Computers & Internet
1helpful
I have a Dell 1525 Inspiron laptop. All of a sudden it DOES boot up, (I can hear the HDD) the LCD display looks lit up, but NO DISPLAY either of boot up or windows. I hooked up an external monitor an
It sounds like your LCD might be bad. The fact that you can see the display on an external monitor tells you that your video card on the motherboard is ok. Is it booting all the way into windows so that you can see the desktop on the external monitor? Take a flash light and look real hard at the LCD on the laptop. Sometimes you might be able to faintly see the same thing you are seeing on the external monitor. If you can faintly see the icons or desktop that means your LCD Inverter is bad. If you see nothing, you screen probably needs to be replaced. I would find another repairman because you don't need to know anything about the bios to replace the lcd monitor. Look on ebay and type in "Dell Inspiron 1525 LCD Screen" . Set the options to "Buy It Now" so that you can only see the items you can buy and not bid on. Also set the Sort By to: "Price + Shipping Lowest First". The first thing you will see are LCD Inverters that can be purchased new for under $10, then you will see used LCD Screens from $50 - $75. A new LCD Screen for your system can be purchased as low as $86.69. Also notice that it shows that the screen will not only fit your dell inspiron 1525, but also the 1501, 1505, 1520 and 1526, so once again it sounds like you need to boot the repairman that says you need to know the bios number. If you need a good hones repairman try: http://www.generalsystemsconsulting.com They will fix it and ship it back to you for less than any quote you get including the shipping. I had a friend that got a quote from HP of almost $400 to replace the screen, they did it for $155
1helpful
6answers
Forgot password
If you Forgot Windows Administrator password and have change the build-in administrator password and now forgot it, you will be unable to hack forgotten windows password by Command Prompt or Safe Mode . Then windows password recovery software is your best choice to bypass the locked out computer, it is the most effective windows password hacking method on the market. Don't take my word for it, why don't you have a look for this utility and try to crack windows administrator password by yourself,
Visit: Software to crack Windows Administrator password.
Hi! I need help with my computer. I use a seagate ST380811AS hard disk in my desktop computer. The problem now, is that everytime I start my computer "A non system disk" appears on the monitor or...
1 Remove any floppy disks or bootable CDs, DVDs, USB flash drives or other bootable media from the computer. Attempt to restart the computer again. Proceed if you continue to receive the error.
2 Restart the computer again. Press the key required to enter your BIOS setup. (The monitor usually displays a "Press [key] to access BIOS" right after restarting your computer. Press the key shown on your screen.)
3 Navigate to the "Boot Options" or "Advanced" menu by using the arrow keys. (The precise menu terms will vary according to your computer and BIOS type.)
4 Select the hard disk that contains your operating system (usually C:) as your primary boot device. Select your CD/DVD drive, your floppy drive or another hard disk as your secondary boot device.
5 Save and exit the BIOS. Proceed with the next step if you see the "Non-system disk error" message again.
6 Restart the computer. Return to the BIOS' "Boot Options" screen by following the steps above, then set the "CD/DVD drive" as the primary boot device and the hard disk as the secondary boot device. Save and exit the BIOS.
7 Insert your Windows installation disc. Restart the computer. Press any key to boot from disc. Follow the on-screen prompts to reinstall Windows.
8 Replace your hard disk drive if you cannot install Windows.
Thanks for choosing Fixya
Sandeep
4answers
Just got a Maxtor MaxAttach 4300 used and need to reset to factory...
Since no one has posted on this I?ll give you my best guess. Disclaimer, I don?t have one of these, Maxtor is now owned by Seagate, they have discontinued support and I can?t find a manual. Having said all of that from what I?ve read this runs Windows 2000 server and allows you to physically connect a keyboard, mouse and monitor to it. I would try connecting these external devices to the box, boot up and try logging in. If you literally don?t know ANY of the passwords you can try booting the system with a utility tool that will find and remove the administrator password. There are several of them readily available (usually Linux based) available for free, here is the link for one: http://home.eunet.no/%7Epnordahl/ntpasswd/. That will allow you to log into the operating system and configure it as you wish. Be aware that this is not supported by Microsoft and could wind up corrupting the operating system. At that point the only option would be to rebuild the server software from scratch. Good luck and let us know how it goes or if you have any other questions.
Grand Canyon Tech
Grand Canyon Tech
