Maybe this can help. If not, please supply your TV model.
You need to register with Netflix online first to create a login and password.
Here`s how to:
>> On your computer go to netflix.com then click signup or signup.netflix.com
>> Fill all the necessary information they needed.
>> Purchase any plan they offer after you created an account(Optional as you can avail a trial version for 7 days)
Now go to your TV
>> Turn the TV on then hit menu
>> Go to My apps menu
>> Select Netflix
>> Sign in with your username and password
>> Take note of the code
>> Go to your computer and login to netflix.com/activate and type in the code to activate.
>> Go back to the TV select finish to start the service
Important:
Make sure your TV is connected to the internet, either wired or wireless
Here are the three methods to connect wireless on your TV:
Scan and connect
>> Turn on the TV
>> Go to Menu
>> Go to Network settings
>> Select easy then scan for networks
>> Select and connect
Connect using WPS
Press the WPS button(Padlock with signal wave) on your TV`s side panel then on your router.
Note:
You only have two minutes before the router turn the WPS off
Add network manually
>> Go to Menu
>> Select manually add network
Type and select the appropriate settings:
SSID: Name or the Wireless network
Security: Either the WEP, WPA, WPA2 or WPA+WPA2
Passphrase/Passkey: Type in the password
Wait for a prompt that the TV is connected to the internet.
