My Samsung NP350V5C-S01CA laptop will continuously shutting down unexpectedly. My inner screen broke not to long ago and then a week after that happened, the battery died (it doesn't recharge anymore). Since the battery issue started, my laptop has been shutting off unexpectedly. I have since replaced the screen and am waiting on a new battery, but I don't understand why it's shutting down at weird times, even with the AC adapter in. Help?!!
SOURCE: IBM Thnink Pad R52 Shuts Down unexpectedly
it might be the battery, try plugging it in while doing that.
SOURCE: blinking AC light with/without battery, computer shuts down
I want to try a very simple thing, cause it happened to me, while I am working on my computer , it shut down unexpectedly... cause the processor is working with its full performance and no enough cooling around the laptop. so while I move to other place and also I raise the laptop a little bit from the back to let the fans (bottom of the laptop) works perfectly .
try to open it again and do so.... may be it is a so simple thing that was far from your mind like I was before... good luck
SOURCE: Amilo Pro v2065 shuts down when battery is plugged
you need do check:
1) no charging means adapter input problem, first check your adapter DC output voltage is ok
2) check DC jack socket on the motherboard:
--- DC socket any pin disconnected, you need use iron and flux to fix it
--- DC socket damage(broken),you have to change it
3) if DC socket connection normall, the DC/DC circiute near around DC socket some component damage, you need find a technacian to repair.
hope help you to deal it well
SOURCE: My Dell 5160 laptop slows down with the AC adapter plugged in.
try running ur laptop using the adaptor without the battery in it's place and run it with just the battery...note the difference....it may be a power surge/short issue....some times the battery is supplying power along with the adaptor to the notebook and the power circuit in there is not able to take dual power....check your power options setting in Control Panel...
also do this
clean ur system use Tuneup Utility get it from my website Dowload page
www.sureshayyar.110mb.com
use all the tools and option in that tool...the best is 1n Click Maint in there .....it fixes all ur issues...
SOURCE: Laptop shuts down after 20 or 30 minutes with one
Please refer to manual and run system restore to system default settings as if it was from the package.
Cheers.
