RCA M4304  Digital Media Player Logo
A
Anonymous Posted on Jan 17, 2014
Rca m4304 get the need 20mb space for profiling message. I download the firmware installation from rca. It gives me the instructions but the app will not open
When I try to download the firmware app from rca I get the instructions but the app doesn't open
4 Related Answers
Anonymous
  • Posted on Jul 10, 2010
SOURCE: BOUGHT RCA 4304A, 06/01/10. WORKED FINE. WHEN I
Damn. I have the exact same problem and I'm working hard to solve it. I will definitely let you know if I got a solution to this problem. Let me know if fixed it.
Anonymous
  • Posted on Jul 11, 2010
SOURCE: when i turn my rca m4304-a on it says profile
We are having the sam eproblem with the asking to free up 20mb. Your solution (The player needs free memory space for building up the playlists: delete the amount of data off the player.
Connect to the computer and backup all the data from the player onto the computer.
Next delete some of the saved data from the player to free at least 20 MB of memory.
All support for the RCA M4304 on next page:..... Does not work for us. When we plug it into the computer all it does is show it usb connected but we cant get into player anymore to delete anything. Please advice
Anonymous
  • Posted on Jun 01, 2011
SOURCE: my rca m4304-A mp3 player says profiling requires
Restoring RCA M4304A Recorder Firmware
Symtom: recorder shows OPAL splash screen, then shows "profiling requires20mb of free space, shutting down" and then shuts down. Recorder cannot be accessed by windows or the RCA easyrip software.
Solution: Use the firmware update found here: http://www.voxxsupport.com/images/downloads/OPAL_066F_85A4_85A5_0_1140_SIG.EXE
This update needs to be ran on an xp computer running 32 bitOS. It was tested in a Win 7 64bitmachine and proven to not work.
Necessary steps taken to get the firmware to properlyrestore were as follows:
1. Hold in the power (menu) button for 10 seconds(the splash screen will show and it will give the error message, ignore it)
2. While still holding the power button, press theplay/pause button and hold down.
3. Release the power button while still holdingdown the play/pause button and wait 5 seconds.
4. While still holding the play/pause button plugin the usb cable to the recorder. Continue to hold the play/pause button foranother 5 seconds after plugging the cable in.
5. Release the play pause button then launch theEXE for the firmware update. Minimize the instruction screen so you can see thefull update screen.
6. Leave the format checkbox checked (check it ifit isn't checked) formatting is crucial to this working.
7. Once the status in the update window changesfrom initializing to ready click start to update the recorder. It will go through formatting, then updating.
8. Once the status shows complete disconnect therecorder and with any luck the recorder is usable again. The media files will obviously have to bereloaded, but the recording is functional at least.
hunter19_46m
Curtis Sewell
  • 7482 Answers
  • Posted on Sep 27, 2011
SOURCE: I get this message on my RCA 4304: "Profiling
Hi bentleyme...
Try this solution to your problem
Deleting Files,Pictures,Videos,Audio Books, Apps,etc. from MP3 Player/Ipod
BIG WARNING: DO NOT DELETE THE FILES NEEDED TO OPERATE YOUR MP3 PLAYER.
Hook up your mp3 player to your computer
Go to your desktop and double left click on "My Computer"
When it opens you will see listing that says "Devices with Removal Storage" your mp3 player should be listed there.
Right click on your mp3 player, and a window will open, right click on "Open" and now your files/songs should be visible.
Hold the left click down and drag it across all the files/songs that you do not want this will highlight the files/songs you do not want, release,right click and then click on "Delete"
Now you mp3 player should be clear of the files/songs you do not want.
ONE MORE BIG WARNING: BE CAREFUL AND DO NOT DELETE THE FILES NEEDED TO OPERATE YOUR MP3 PLAYER.
Please take time to rate me thumbs up
3helpful
I keep getting this error... "Profiling requires
Hi,You just need more space on your player. Just connect to your computer, back up files, then delete enough to leave 20mb. Hope this helps! Oh and for all the support for the M4304 visit this page:http://www.rcaaudiovideo.com/product.aspx?product=420
When I try to turn on the player a message comes up "Profiling requires 20MB free space. Shutting down"
Unplug the mp3 from the USB
press and hold the menu button for 10 seconds
release then press and hold the play button
-- while holding the play button plug it back in. Wait until it says intializing, then release the play button and press start.
1helpful
The mp3 won't stay on, it'll turn on and say "profiling requires 20mb free space shutting down!" what do i do?
the data may contain virus. backup the data and format the memory and restore the data.
1helpful
My m4304 rca mp3 player has and error message that says "profiling requires 20mb of free space. shutting down!".... yet my computer will not recognize that it is plugged in, nor will the thing turn on at...
First: Try to delete some songs, it may be that you are over the capacity of your player. If it does not work..
Second: Hold the power button for 10 seconds, it may reset it. If still does not work
Third: Go to and try to update your player (but do a back up of all your files if possible):
http://voxrightnow.custhelp.com/app/answers/detail/a_id/7312/kw/m4304/r_id/103795
3helpful
2answers
My rca m4304-A mp3 player says profiling requires 20mb free space shutting down and then when i try to hook it up to the computer it will not show that it is hooked to the computer and goes off
BOUGHT RCA 4304A, 06/01/10. WORKED FINE. WHEN I TURN IT ON IT SAYS PROFILE REQUIRED 20MB FREE SPACE NEEDED, THEN SHUTS DOWN. TRIED FREEING SPACE BY CONNECTING TO COMPUTER, BUT WILL NOT COMMUNICATE, PLAYER...
7helpful
2answers
When i turn my rca m4304-a on it says profile required 20mb free space shutting down.. how can i fix it?
Loading
i have the same problem and its ********
12helpful
3answers
Rca opal 4gb M4304-A has completely stopped functioning
Wow, I didn't realize so many people were having the same problem I was having. First try re-installing the firmware for it. Since your computer won't recognize it you will need to download the software, then you will have 2 boxes pop up. One is the install instructions and the other is the actual program install. You will have to hold down the play button on your player while you plug it into the computer. DO NOT RELEASE THE BUTTON UNTIL THE PROGRAM SAYS "INITIALIZING".
It should work fine once you do this. I spent 3 hours going through RCA's website before I came across this step.
2answers
I just bought a RCA m4304 and when plugging it into the computer for the first time it shows opal initializing and won't turn on at all or go past the screen. Never got music on it or was able to use it.
When I turn on my M4304 OPAL it says Initalizing..... profiling requires 20MB free space. Shutting down. Then shuts off. If I plug it into my computer to try and delete files. My computer does not recongize it. It shows that is have a full battery. I have tried all the re-set methods given. I have tried downloading an upgrade. Nothing works. Can you help?
Top RCA Audio Players & Recorders Experts
 Grubhead
Grubhead
Grand Canyon Tech
Grand Canyon Tech
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
