Copy lamp ok; cable/connector ok ; i am just change the mainboard with the new one. SHARP AR 5020 error F5-02 pls can u give some tips very helpful its urgent sir
You reset your eror code program c#0#
Salut l'unité optique de ma sharp ne s'initalise pas corectement et tremble lorsqu'il faut fire le retour .sil vs plais aidez moi si vous avez une solution
Make sure you have connected the fuser unit connectors well.
Sounds like you did everything correctly. I would either return your Main board and ask for a carriage unit and cable or call for a service tech(sharp-authorize dealer).
