SOURCE: Dometic NDR 1062 Interior Light Assy Fasteners
I finally did a Google search for the NDR 1062 and found the Illustrated parts breakdown on PPLs web site. Also, received an email from a helpful reader of Fix-Ya Site with another site that had the parts manual.
SOURCE: my dometic refrigerator is not freezing properly.
If the refrigerator is 38 degrees and the freezer 18 degrees , both are not normal.
Have you used any hard and pointed object to remove any frozen food or Ice before this happen?
Have you notice any oily part coming out in the freezer or at the back of the refigerator which will indicate that there was a leak?
there are few factors that may cause your refrigerator to be like that:
1. A possible leak along with the tubing that will cause to loose the refrigerant which make the refrigerator to produce ice.
2. lost Compression (Motor compressor) this happen eventually specially the refrigerator is more than 10 years old
the best way to find out is to call a technician and have them check it
SOURCE: Light will not go out on Dometic Referigerator ,
Tell you what I am going to do and that is because the model number you listed in your post may be missing something I am sending you to
Click Here=> GasRefrigeration.net and if you cannot find it there on their site you can call them in the morning, Please rate my solution after I have helped you resolve the problem and communicate with me. I am offering my help to you free. If need you may contact me here on Fixya or my Forum=> Appliance 911 My contact information is located above the Fixya Ad on my blog here=> Sea Breeze Appliance Parts and Technical Services, www.pcappliancerepair.com
Thanks, Sea Breeze
SOURCE: My Dometic NDR1062 only runs on gas, its set for auto and has 110
There is a control board and a step down transformer that may be at fault.
These should be located in the lower rear of the unit.
