A
Anonymous Posted on Jan 18, 2014
Km 6030 copier c 0970 - Copystar Office Equipment & Supplies
Kyocera km-6030 printer
try turning off copier unplug from wall for a few secs or try to restart your computer
How to remove C6400 error in kyocera km 6030
http://www.copytechnet.com/forums/kyocera-mita-copystar/11146-kyocera-km-4050-c6400-error-codes.html
Eroor code 4200
your problem is not the dv unit it is the laser that makes the image on the drum
Km 6030 all codes solution
there is a problem with me code of 6030.what,s wrong there?
2answers
Kyocera error c7200
km 6030 machine have a code on screen c7200 so how i solve it
6030 display
KM-6030 or FS-6030. if it is the fs open the fron door, remove the waste bottle and replace it with a new one (they come with the toner). if it is a KM or CS 6030 that should be covered under your service plan. if you are running a segment 3 machine without a service contract you need to reevaluate your situation.
1helpful
How do I install driver for Kyocera CS 5035 on MAC
Kyocera and Copystar models are the same just replace KM with CS.
The following instructions should help you. TO download the current driver use this link to th emanufacture website; http://usa.kyoceramita.com/americas/jsp/Kyocera/resource_details.jsp?rid=18657.
Kyocera Printer Drivers and Mac OS® X 10.5 Leopard FAQ:
Is the installation for Mac OS X 10.5 the same as for Mac OS X 10.4 and earlier? Mac OS X 10.5 introduced a new printing architecture that requires changes to the installer and installation process. For this reason, Mac OS X 10.5 requires a new printer driver installer.
I cannot see my Kyocera AppleTalk® printer. How can I make it visible to OS X 10.5? AppleTalk is disabled by default in Mac OS X 10.5. Enable AppleTalk to discover your Kyocera printer.If you use the Kyocera installer, a message will appear, asking you to enable AppleTalk. Click Yes to continue the installation.
I cannot find Printer Setup Utility on Mac OS X 10.5. Is it still supported? Apple has removed Printer Setup Utility from Mac OS X 10.5. To install a printer, open System Preferences and click Print & Fax.
When I manually install a printer, multiple PPD files are listed for the same Kyocera model. Which should I choose? When manually installing a printer or changing a PPD for a installed printer, both Linux and Mac OS X PPDs are listed for some older Kyocera models due to a change in PPD handling in Mac OS X 10.5. Linux PPDs can be identified by the word Gutenprint in the PPD filenames.
Supported Multifunction Printers: KM-1650, KM-1815, KM-1820, KM-2050 ,KM-2530 ,KM-2550, KM-3035, KM-3050, KM-3530, KM-4030, KM-4035, KM-4050, KM-4530, KM-5035, KM-5050, KM-5530, KM-6030, KM-6330, KM-7530, KM-8030, KM-C830, KM-C830D, KM-C850, KM-C850D, KM-C2520, KMC2525E, KM-C2630, KM-C3225, KM-C3225E, KM-C3232, KM-C3232E, KM-C4008, KM-C4035E, CS-1650, CS-1815, CS-1820, CS-2050,CS-C2525E, CS-2550, CS-6030, or newer. Supported Printers: FS-820, FS-920, FS-1018MFP, FS-1020D, FS-1030, FS-1100, FS-1118MFP, FS-1300D, FS-1800, FS-1800+, FS-1900, FS-1920, FS-3800, FS-3820N, FS-3830N, FS-6020, FS-6026, FS-9100DN, FS-9120DN, FS-9500DN, FS-9520DN, FS-C5016N, FS-C5020N, FS-C5030N, FS-C8008N, FS-C8026N, FS-C8100DN, or newer.
I hope this is helpful,
Shawn
Getting an error code of C6030
KM-5050 error code displaying C 6030 how can i remove this code WebRepOverall ratingThis site has no rating(not enough votes)
Top Copystar Office Equipment & Supplies Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Norman Weimar
Norman Weimar
Are you a Copystar Office Equipment and Supply Expert? Answer questions, earn points and help others
