Either mix too rich, torque set too low, shaft spring bent, compressor relay blown, compressor contactor shorted, refrigeration valve solenoid bad, or filter dirty thus reducing air flow. if it's both sides, clean the filter and check the compressor relay (behind right side panel, behind plastic cover on compressor. if you smell burning electric, replace) and the contactor (behind right side panel at the top, tan box with wires. press the tiny button to start compressor. if it doesn't start, replace). if it's only one side, check the valve solenoid (inside left side panel, there are 2 valves. remove plugs from each and retouch to terminals while on. if they click, they work).
Its defrost problem, the freezer should cool,
then freeze, then defrost cycle should start. In your case freezer is cooling,
then freezing, but its not defrosting. That's why fridge section is not
cooling.-------
Click this link below and follow the
troubleshooting:----
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
This will help.Thanks.Helpmech/.
