Question about Motorsports
2001 pt cruiser rear wiper doesn't work
Doesn't work
    Scholar:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 97 Answers
Check all fuses and if good you will have to pull the covering from the rear hatch to get at the wires so you can check with a test light or volt meter to see that you are getting voltage when the wiper switch is activated. If there is no voltage try to see if the wire is damaged somewhere or if the switch itself has gone bad. If there is voltage them the motor may be burned out. You will have to have the things that you find replaced if bad.
Posted on Oct 29, 2018
Anonymous
SOURCE:
Anonymous
SOURCE: 2006 PT Cruiser Wipers Don't work
I had the same problem. It was the wiper computer module according to the dealership. Fortunately it was covered under extended warranty and cost $100 deductible.
Posted on Nov 21, 2008
Anonymous
  • 290 Answers
SOURCE: chrysler pt cruiser fuel filter location?
Under vehicle, center, below seating area, mounted on top of fuel tank, in fuel pump module
Posted on Mar 27, 2009
c17hydro
Greg Bernett
  • 2989 Answers
SOURCE: Location of powertrain control module on 01 PT Cruiser?
The PCM attaches to a bracket welded on the dash panel
Posted on Oct 31, 2009
BCAS1298
Alexander Mimun
  • 3092 Answers
SOURCE: replacing a starter in a PT. Cruiser 2001
Remove battery and battery support you'll be able to undo starter bolt's trough there and slip starter out.
Posted on Dec 08, 2009
Testimonial: "This didn't help, because you had to remove the engine structural collar under the starter to get at the starter bolt. It was more complicated."
Anonymous
  • 5 Answers
SOURCE: 2001 PT Cruiser: How too remove crankshaft pulley 2001 PT Cruiser...
GET A 3 SPOKE PULLEY EXTRACTOR AND SCREW IN THE BOLT BUT IN THE CRANKSHAFT HOLE PUT A MUCH SMALLER SCEW SO YOU WOUNT MESS THE INSIDE UP
Posted on May 26, 2010
2001 PT Cruiser rear wiper stops in the wrong position
Try to open the wiper motor gear section only, maybe the wiper parking contacts need a little cleaning. Check also for possible cracks on gear.
Jun 27, 2018 | Cars & Trucks
Do you have a schematic for a 2001 pt cruiser wiper circuit
Go to www.bbbind.com you will find free wiring diagrams there . On the home page click on technical information , then tsb's an wiring diagrams .
Oct 29, 2015 | 2001 Chrysler PT Cruiser
My 2006 PT Cruiser rear wiper does not work. The motor tests okay. The rear washer works. The wiper is not getting power.
It may be related to TSB 08-027-06 which calls for a TIPM software update. The TIPM module is part of what controls the rear wiper. You will be stuck going to a dealer to have the software update performed though.
Apr 17, 2011 | 2006 Chrysler PT Cruiser
I HAVE A 2006 PT CRUISER THE REAR WIPER JUST STOPPED WORKING
The wiper motor may have gave out its located in the rear hatch interior panel. Although your problem could simple be that the fuse has blown and do need to replace it. Generaly the fuse panel is located directly under the dash panel and some times in the glove box. The only other promlem whould have to reside id a bad wiring conection simply use a voltage meter to check continuity.
Dec 06, 2010 | 2006 Chrysler PT Cruiser
2001 pt cruiser , the wipers dont throw whater but the pump sound li ke its working , so i thing the hose is cloged, how can i fi it ?
take a straight pin and check the sprayers holes then pull hose of sprayers an turn on spayers to see if any fluid comes out
Feb 09, 2010 | 2001 Chrysler PT Cruiser
06 PT cruiser rear wiper stopped working and I can not find fuse box where exactly is it
the fuse box is under the hood basically behind the battery but if the power windows are workng the fuse is good.you may have a wiring problem or a bad motor
Jan 07, 2009 | 2006 Chrysler PT Cruiser
Nov 13, 2008 | 2006 Chrysler PT Cruiser
Motorsports Logo
319 people viewed this question
Top Motorsports Experts
chuck ringwood
chuck ringwood
Andrew Taylor
Andrew Taylor
Simon H
Simon H
Are you a Motorsport Expert? Answer questions, earn points and help others
