Nokia N95 Cellular Phone Logo
Posted on May 30, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Nokia n95 8gb lcd is blank but i hear it's turning on
Nokia n95 8gb help
Aaron Wilson
Level 2:
Sniper:
  • Expert 87 Answers
  • Posted on Aug 15, 2009
Aaron Wilson
Expert
Level 2:
Sniper:
Answers
87
Questions
0
Helped
34096
Points
224
If its blank you have to replace the lcd screen with a new one.
sometimes it maybe a flex cable problem which occurs in some slide phones.
at mobile phone repair stores, the cost of an original lcd screen replacement is usually $150-$200, though sometimes an original lcd screen may not be fitted into your device but rather a hong-kong made one which is similar to the original but is less brighter and a little less sharper.
if you take it to a nokia care centre to replace the lcd screen you may have to pay over $250.
you can just buy an lcd screen off ebay, replacing the lcd screen yourself isnt hard with the tools provided. you just have to take the ribbon cable from the old lcd screen and insert the new lcd screen and plug in the ribbon cable for it.
the reason for original Nokia n95 8Gb lcd screens being so expensive to repair/replace is that it is also the same lcd screen used for the Nokia N96.
cheers.
Sanjiv Sharma
Level 2:
Filmmaker:
Uploaded 5 video answers.
  • Expert 139 Answers
  • Posted on Apr 19, 2016
Sanjiv Sharma
Expert
Level 2:
Filmmaker:
Answers
139
Questions
0
Helped
398522
Points
241
Insert s sim ...switch on ur fone anf make a call to yhid fone.....if call rings tjen not much problem.... Change the slider fpc(ribon).
If still problem is there then change the lcd.
If call fails then get the software done.
1 Related Answer
Anonymous
  • Posted on Jan 19, 2009
SOURCE: nokia n95 8gb blank screen
can u try replace the flix sir
1helpful
My phone model nokia 7210.it s showing a blank display whenever im trying to switch it on.it s not working
if nokia them heared o and change the display LCD, if not heared the nokia jingle tone you have to reinstall the software.
please keep vote me if this will help you
Jul 27, 2011 • Nokia 7210
My phone doesnt show colour anymore just a black blank screen
There can be many things to cause that. You have to be more specific and tell us how it happened. But if it vibrates when you 1st turn it on and afterwards there is no Nokia chime, then your phone needs to be flashed with new software. If you hear the Nokia chime, then it might be just a bad LCD or a Main flex cable.
1helpful
My nokia 6111 screen goes blank
It is not a common problem. It seems that either the connection to the LCD is broken somewhere, or the LCD is going or the display IC has gone. It it is the last (display IC) then the phone has to be thrown away as even Nokia thinks it beyond economic repairs. Earlier two can be rectified by Nokia Care.
2helpful
2answers
5310i's screen going blank
yh
u shud go to the nokia showroom or the shop where u purchased ur phone and ask them
to check ur screen. if u dash ur phone everytime it will really damage the entire system in
so visit a nokia dealer and get ur job done
though it may cost u few bucks its better than buying a new phone
SCREEN IS BLANK BUT IT HEARD IT'S TURNING ON
since the phone is thrown at wall more than one part could have been damaged.only thing you can do better is take it to service center and get repaired.since it is an expensive phone and the problem is delegate and unpredictable , please dont try to repair it yourself..thanks for using fixya!. please dont forget to rate my solution!
My screen went blank and i can't see anything
It sounds like the LCD backlight went bad. If you are still under warranty, get it replaced.
If not, you can buy a replacement 5310 LCD and replace it yourself.
A new 5310 display costs about 20 dollars from ebay.
I wrote a detailed guide to help you put in the new Nokia 5310 LCD screen.
Check it out at the following link for the guide and links to buy the LCD
Nokia 5310 Screen Replacement
Hope that helps
4helpful
2answers
Screen blanking off
please see for the technician the problems is in the LCD of the phone you might have to replace it.
BLANK SCREEN
try to open it and check for loose connection from your lcd to your cellphone board.
10helpful
3answers
Nokia 6300 diagram.Mic error.
my china nokia 6300 lcd show blank mean white colour display show plz help me about his point of lcd showing
1helpful
3answers
Nokia 6230i my screen keeps going blank
remove MMC from ur mobile,then switch on ur mobile then press restore key that is *#7370# after inserting this u have to enter 12345 as factory code, then it will start
Top Nokia Cell Phones Experts
Kolbrun...
Muhammad Irshad...
Muhammad Irshad...
