I've tried turning it on and it wont.Even if i plug it up to the charger it wont work usually if i plug it into the charger it will show the charging symbol but it wont even do that now whats wrong?
All I cant suggest if its still under warranty take it back to place of purchase,my flatmates boy had same problem the guy at the shop where it was brought from fix it in about 2minutes and no charge .
Try this
Plug in the charger
Hold down Volume + and Power buttons at the same time for at least 15 seconds. Remove the charging cable from the tablet, then plug it back in.
If the tablet works while plugged-in to the charger, yet dies immediately when the charger is disconnected, it means that the rechargeable battery in the tablet is dead.
If the unit will not turn on at all, even with the charger attached, the charger itself may have failed, or the unit may be having other issues.
At this level of charge their is not enough to start the boot process , if it doesn't charge at all their may be a fault with the Battery cell , however i had a similar issue, just leave it for a while, if their is still no indication that its charging or it wont turn on their could also be a problem with the Start Button
There should be a tiny reset button or pinhole (use a straightened out paper clip). If reset button/hole itself does not work, try pressing it while holding down the power button at same time. Otherwise, it sounds like you have a battery/charging issue (try another charger cord if available).
I have a Nextbook 8 inch Andriod Tablet
