Our old library copier (Xerox CopyCentre C123) is not connected to network. It used to be connected to copy-card reader. We wish to now simply use it as upstairs copier for staff.
Http://www.support.xerox.com/support/copycentre-c123-c128/support/enus.html
This is how to turn off Auditron but this is the same menu as "foreign interface device" or copy card.
SOURCE: Xerox Copycentre C123 Creating a Ghost Image
First place an original on glass and make a copy -- mark #1. With that same original on the glass, move the exposure all the way light and make a copy -- mark #2. Again with the same original on the glass, move the exposure all the way dark and make a copy --- mark #3. Place #1 in the middle so the the copies read --- #2, #1, #3. The #2 should be the lightest and #3 being the darkest. If #2 is darker than #3 you have a developer problem and you need to call for service. If #1 and #2 are bad and #3 is a good copy your machine probably just needs a good cleaning, mainly the optics and charge units. If all 3 copies are still poor with the speckles, your are looking at the PCU ( photo conductive unit) also called the drum unit. You can order this unit online -- it is a customer replaceable item.
SOURCE: Need to establish PIN/Code for machine - help xerox c123
The following information describes how to register userIDs and usernames, login names, and passwords for authenticating accesses attempted through the network for scanning services, and impose restrictions on the maximum number of pages to be copied or scanned. Up to 500 user accounts can be registered.
NOTE: You must be a System Administrator to perform this solution.
NOTE: The default userID is 11111, and the default password is x-admin (must be entered in lower case). If the userID and / or password have been forgotten, a service call must be placed.
SOURCE: My Xerox Copy centre C123 shows error code 124-315
Thats a weird one. The machine is detecting the wrong speeds.
Try this.
Then look at these 3 locations and see if they match, If they do not set them to match the machine speed.
Testimonial: "Thankyou,and need more help. chose NVM read/write & enter value700-600, it shows 65000 current value what should i enter as new value?"
SOURCE: CopyCentre C123 Copier Copier: CODE 116-331...
It may be a defective Main System Controller board 160K91660 or Hard Drive 960K01120.
There is a diagnostic which requires the Xerox Technician's Laptop to test the Hard Drive.
You might get lucky just reseating the Hard Drive.
Whit
Item, Inc.
SOURCE: error U4-1000 (Xerox CopyCentre C116 copier)
U4-1000 Indicates Fuser on time failure
Follow these steps:
1. Check for paper on the fuser.
Y remove paper N proceed to step 2
2. Check the installation of the fuser assembly, make sure it is securely installed.
Y reinstall fuser N proceed to step 3
3. Remove the fuser. Check the conductivity of the contact points of the thermostat, are the contact points connected
N replace the fuser
