I turn it on and it says enter drivelock password which i enter 1977 then it says enter password which is the same 1977 then you see the words safe mode in all four corners of the screen then it says an invalid parameter was passed to a service function then the only option in that box is to click ok so i do then it goes back to enter drivelock password
Never post passwords in a public forum.
no OS stated but of window 10 safemode is totally different now.
google that, and its like asked 1million + times and same for answers.
sounds like your PC is infected to me
some PCs now, if the OS detects serious problems (corruption)
it goes to safe mode automatically.
my guess is that is what happened.
because going INTO safe mode is more tricky, no more F8 key magic in W10
so what OS< never post any PC questions lacking what OS you run. OPERATING SYSTEM.
SOURCE: hp pavillion trying to boot from dos mode
my pc is writting Disk boot failure, insert seystem disk and press enter. pls help.
SOURCE: Drivelock password
only one best way is, trying to remember password because it's no so easy to unlock drive. And if you really wanna get unlocked your drive then you need to send back your drive to manufacturer because there are no such an easy way to unlock drive.
but it's expensive to get recover back from manufacturer so it's better getting new one.
thanks.
SOURCE: Presairo V5000 notebook will not boot
Try this, get a boot able CD copy of RIPLINUX 6.2 nonX. Go into your Compact bios and select CDROM as the first boot device. Open cd dvd player and install 6.2 Power down and then power up to 6.2 Install GRUB and select HARD DRIVE Partition #2 from the menu and wait.
Now here is what will happen. GRUB will load and execute drive partition #2 which contains the original factory install for your Compact V5000T. Warning!!!! You will lose any customized programs that where added after you bought your computer (goes back to factory default operating system) by reformatting #1 partition. There are utilities that can retrive the contents of a formatted partition, but this is beyond the limits of this topic. Use Google to search for those utilities. They are sometimes free.
SOURCE: How do I get past this Drivelock HDDBay password
Hard Drive is locked. Needs password from whoever you got it from or replace it with another hard drive.
SOURCE: I forgot my administrator password
Forgetting your Windows administrator login password. With no way to get into the system, you can’t even perform basic maintenance, let alone a thorough tune-up. Formatting is always an option, but we consider that a last resort. (Plus, guess who’s going to have to help reinstall all the programs lost after a wipe?) But all hope is not lost. There are a few ways to actually retrieve a lost Windows account password. Read on, and we’ll show you the light.
1st Method:
The first thing which you check if you forget login password. When we install Windows, it automatically creates an account "Administrator" and sets its password to blank. So if you have forget your user account password then try this:
Start system and when you see Windows Welcome screen / Login screen, press ctrl+alt+del keys twice and it'll show Classic Login box. Now type "Administrator" (without quotes) in Username and leave Password field blank. Now press Enter and you should be able to log in Windows.
Now you can reset your account password from "Control Panel -> User Accounts".
Same thing can be done using Safe Mode. In Safe Mode Windows will show this in-built Administrator account in Login screen.
2th Method:
There are a lot of Windows password revealers and crackers available, but we’ve found that Windows Password Recovery Tool is the most effective.:
Windows Password Recovery Tool is one of the easiest password recovery tools to use. It allows you to reset a user account password, including the Administrator password. It is also a relatively small download.
Windows Password Recovery Tool Service: http://www.windowspasswordsrecovery.com
The Compaq drivelock feature is designed to protect the data on a laptop's hard drive by assigning a password.
This password protects the drive in the event the laptop is lost or stolen, but can be removed when necessary.
Knowing how to remove or change the drivelock feature can make your Compaq more useful and more secure.
Power on your laptop and enter the drivelock password you established when you turned the drive protection feature on.
You will need this password to access the drive and turn off the drivelock feature.
Click the "Disabled" option in the drivelock menu.
This will turn off the drivelock feature on the Compaq laptop.
Do not enter anything in the password blocks.
Log on to the laptop, click the "Start" button and choose "Shut down." Choose "Restart" from the menu to power cycle your laptop and verify the drivelock setting is off.
If the drivelock setting is off you will not be prompted for a password when the laptop starts up.
hope this helps
