I would get a test light and see if the remote line is still working. Otherwise, yes you probably fried it. Doesn't take much in car audio to fry an amp.
Testimonial: "The fact that the amp powers on at the same time as my HU would determine that the remote wire is sending power, correct? If I have fried the amp is there a likely part that is replaceable such as the PCB? Also, why didnt the 20ah blade fuse protect the amp if this is the case?"
SOURCE: power light
Hi Bill, I believe the power problem is related to the Remote wire which should be blue or yellow. The remote wire is suppose the turn the Basslink on and off when the radio is turned on and off. The yellow wire is normally used for power antenna. Traditionally the remote wire is blue. You can use a Speaker level adapter and splice in with the L/R rear speaker wires, and the adapter will convert the speaker level to line level. The output of the adapter will go to the Rear speaker input on the basslink., Write back if you need more detail on the adapter.
SOURCE: no power
Other than the +12V, the ground (-) and the 2 RCA inputs, normally external amps have also a remote trigger which switches it to active on. The remote trigger is activated by a wire from the head unit. Colors would either be yellow or blue but depends on manufacturer of head unit. Alternately, you can connect a simple toggle on/off switch to activate the external amp.
Additionally, pls verify that the 2 RCAs from your head unit are audio out and not audio in for aux source.
Good luck and kind regards.
SOURCE: Infinity basslink is messed-up
You may have blown the fuse in the AMP. Check it and let me know.
SOURCE: Basslink Powerlight comes on then fades quickly
check to make sure your remote wire is hooked up to your amp turn on that runs straight out of the stereo not your power antenna also make sur you have a clean ground(no paint or rust) and also check your connections make sure you have a strong connection to all wire hook ups.......you should check to see that your remote wire has no tears in it or small rips or cuts because that can interrupt your current to and from the amp and radio
SOURCE: Infinity Basslink not producing any sound. Green light on.
check that fusse under the hood if its blown pull it out and replace it wont hurt anything if u pull it out an put it back in if the cars off.but if ur getting power lights on the amps then more then likely ur fuse isnt blown.id start by checking the audio cables are produceing sound.if u need more help let me know [email protected]
