The VT-2431 allows 4 handsets to register.. I did this.. I needed to replace 2 that failed, but the new ones won't register as the limit has been reached... Apparently, I need to "reset the base" with the reset code.. I am not sure what steps to take to reset the base.. Please help... -Guy I have the same problem. I've emailed VTech support for an answer.
This worked for me after lots of digging....If you have already tryed reregistering your handsets and can only get two-or three to work try this and deregister them and re-register. If your base model number is vt2431: Take the handset out of the base, press **335782 on the dial pad of the base. (do not have the line active or anything , just put the (2) stars and 335782 in (no spaces) on the base unit. This will de-register all of the handsets at one time. Then just re-register the handsets...
Testimonial: "This works perfectly!!! I don't know how you found it, but GREAT JOB!!! THANKS!!!"
Solution works GREAT!!! Thanks!
