Question about Konica Minolta Di3510 AllInOne Laser Printer
How do i turn off dhcp & set a static ip on a di3510?
  • Konica Minolta Master
  • 6,862 Answers
Your turn off DHPC at the DHPC server, if you wish to set a manual IP at the Copier, log in as administrator, and set up the for static IP vise DHCP
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Posted on Jun 25, 2016
2 Suggested Answers
6ya staff
SOURCE:
Ty Schmidt
  • 118 Answers
SOURCE: Hi, Our Konica Minolta printer
it will be easier to set the copier up with a static ip. then the server can find it easier. to do this go into admin mode and change it.
Posted on Oct 16, 2011
How to stop user privately setting up a static IP address?
Huawei S2300/3300/5300 series switch although no H3C switches am user-bind command, but through the DHCP Snooping function can also be realized IP+MAC+ port binding to prevent users set up a static IP address. For example, if the request port Ethernet0/0/1 in addition to the static IP address for the 1.1.1.2, MAC address for the 001c-2309-9aa7 corresponding to the user, all other static IP users can not access the internet. Configuration is as follows:
Configure the device DHCP Snooping
# enable the global DHCP Snooping function.
[Quidway] DHCP snooping enable
# configure user side interface of VLAN.
[Quidway] VLAN 100
[Quidway-vlan100] quit
[Quidway] interface Ethernet 0/0/1
[Quidway-Ethernet0/0/1] port default VLAN 100
[Quidway-Ethernet0/0/1] quit
# enable VLAN DHCP Snooping function.
[Quidway] VLAN 100
[Quidway-vlan100] DHCP snooping enable
# configuration interface for packet inspection at the user side
[Quidway-Ethernet0/0/1] DHCP snooping check ARP enable
[Quidway-Ethernet0/0/1] DHCP snooping check IP enable
# configuration static binding table entry
[Quidway] VLAN 100
[Quidway-vlan100] DHCP snooping bind-table static IP-address 1.1.1.2 mac-address 001c-2309-9aa7 interface Ethernet 0/0/1
Aug 06, 2015 | Huawei Boxed Ls-s2318tp-ei-ac Quidway...
We are using our Konica Minolta Di3510 as our primary printer. It is connected via ethernet. Everything was working fine until we added internet. Now about half the jobs I send to the Di3510 get stuck...
There is too little information to work out your problem here exactly, but I think here is a conflict in your network. I think you have to read the manual of your modem and printer to see for the settings of your network. Is it DHCP? Do you have a fixed IP address for your printer (that is the best thing to do), and is your Gateway address correct with the correct subnetmask. When your printer starts, it 'asks' for a IP address. Your modem 'gives' an address, but it can be a conflict with an other address in the network. If you set a fixed IP address, your printer will always have the same address and can be found... So take the time to look carefully to your modem settings: is DHCP on? Which range will it use? What is the Gataway address, what is your subnet mask? Take also a look at your printer settings: Is DHCP on? Does it have a fixed IP address? And take a look to your printer driver: to what IP address are you printing? Those three things have to match in order to recognize each other.
Sep 06, 2011 | Konica Minolta Di3510 AllInOne Laser...
I am having conflict ip in DHCP mode, I set a static ip still not list the server and not communicate with the network, how do I reset the device to factory settings?
There is no factory reset. If you set a static IP Address, you should be able to PING the L230 from another device on your network, i.e. the server. Please test that. Make sure the static IP address you assign to it is in fact available. Moving forward, it's best to turn on the Gratuitous ARP for your DHCP server so that it will verify if an address is already being used BEFORE giving it out.
Mar 12, 2011 | NComputing L230 Network Terminal
Won't dhcp connect with router
the Di-604 is the router. it will provide DHCP if the DHCP function is turned on. IT will not get its own IP from another dhcp router though. At least I have never gotten any to. I set the router IP address manually and then I set the DHCP range to be something that wont interfere with any other static IP addresses.
For instance. I set the router to 192.168.1.5 instead of its default of 192.168.1.1. Then I set the range of DHCP to 192.168.1.150 to 192.168.1.170
You have to log into the router to do these changes. Your manual will tell you how to do this and what the default IP address is that you will need to type into your browser.
Mar 09, 2010 | D-Link DI-604 - 4-Port Broadband Router [...
Where would i find the static ip adress
Static Ips are the ones that you yourself will define in your every computer in your network. Also, you need to configure your router to use static IP. So, 2 things to remember.
Setting your router for Static IP.
  1. Open your router web interface at http://192.168.1.1 or http://192.168.0.1 (depending on your router model)
  2. Disable the DHCP server by un-checking this DHCP option.
  3. Save your changed settings.
Configuring Static IP of computers.(This applies to MS Windows XP only)
  1. Click Start => Settings => Network Connections
  2. Right click on your LAN Connection and click "Properties".
  3. On the General Tab, scroll down to TCP/IP, Click on it to select and click the "Properties" button.
  4. Make sure that you ticked the option button: "Use the following IP Address" and you need to define the IP.
Mar 05, 2010 | Computers & Internet
I have a yellow machine p400t and i need to give it a static IP address and do this through a linksys router. how do i go about this? do i need to attach it to a computer?
Yes, it must be attached to the network 0. Install the yellow machine software on the PC 1.Log on to the Yellow Machine Manager. Go to “Logging On To Yellow Machine Manager” on page 8. 2.From the Yellow Machine Manager, click Network > Network Interfaces. The Network Interfaces window appears. 3.Click Edit. 4.Select Yes to Enable LAN Interface. Default: Yes (Enabled) • If you select No, all other LAN option fields are blocked. • If you disable the LAN Interface, the only access to the Yellow Machine appliance is through the WAN port. Anthology Solutions does not recommend this configuration. 5.Check Enable DHCP Service if the DHCP service is needed for the PCs attached to the Yellow Machine appliance’s LAN ports. This setting makes the Yellow Machine appliance the DHCP server for your LAN (or sub-network), providing IP addresses dynamically for the clients connected to the LAN ports. Default: Checked (Disabled) 6.Select either Obtain IP Address Automatically from DHCP Server, or Static IP Address. Default: Static IP Address • Choose Obtain IP Address Automatically from DHCP Server if your Yellow Machine appliance connects to either a router that has DHCP service enabled or to a cable modem. This setting makes the Yellow Machine appliance a DHCP client on your network. • Obtain IP Address from ADSL provider is greyed out. • Choose Static IP Address if your network is locally defined and controlled and does not use DHCP services. Type the IP address manually. 7.Specify IP address and Subnet mask if you selected a Static IP Address, and click Apply. 8.Click Yes to confirm, No to abort. The changes takes affect within five seconds after the network interface change notice appears.
Jan 26, 2010 | Anthology Solutions Yellow Machine P400T...
How to set Static local IP Address for D-link DCS 5220 IP Camera? Am using Linksys WRTG54 Router, with SSID & WPA. I had set the D-Link DCS wireless to use the same SSID and WPA, but once I plug out...
To set a static IP on the camera, do the following:
1. Chose an IP address for the camera that is outside your normal DHCP range but within your network subnet.
For example, if your router uses DHCP and gives out addresses in the range of 192.168.1.1 up to 192.168.1.10, you should chose an IP address beyond that (e.g. 192.168.1.20).
2. Login to your camera's current IP address and go to Setup -> Network setup
3. Turn off DHCP and type in the IP address that you chose into the configuration.
4. Restart your camera.
The above should fix your Static IP address question.
With regards to your Wireless question, you should make sure of the following:
1. Your router is set to broadcast its SSID
2. Your router is setup to use WPA (not WPA2)
3. Your AES password in the camera config is the same as that as the routers
Hope this helps
Nov 24, 2009 | D-Link DCS-5220 Network Camera
HP Officejet printer
i assume that your printer is connected to a network. if so, it could be that the printer is set to use dhcp for the ip address. and if that's the case, it's better to set the printer to use static ip address since there would come a time that the dhcp server (a router most of the time) would provide another ip addresses to all the devices connected to it. that could be the reason why you are getting a "no connection" message (disconnecting and reconnecting it at times would solve the problem temporarily).
here are the steps on how to set static ip on the printer using a windows computer.(Note: the installation cd can automatically assign a static IP address as long as the printer does not obtain a dynamic (dhcp) address)
- boot up your computer the normal way so it'll get an ip address from your dhcp server
- then turn off your dhcp server so that the printer will not get any ip address via dhcp
- reset the printer to set its factory default configuration (with no dhcp address)
* unplug the printer from the power
* plug the power cord back in while holding in the printer’s
report button (it will try to find a dhcp server; after about three
minutes of no dhcp response, the printer will default to a static ip address of 192.0.0.192
- then print a configuration page to confirm that the ip address of the printer is set to 192.0.0.192
- then press the report button (wait until IP address is 192.0.0.192 before proceeding. if it remains set to 0.0.0.0, check the network cable connection to the printer and to the network is secure. If some other address appears repeat steps 3 and 4 until the default address appears
- you can now start the software installation cd
*during the installtion, follow these steps:
- select the model of the printer that you are using which is hp officejet before clicking on "next"
- then select "do network settings for me, then press "next
*follow the instructions on the remaining install screens
- the software will pick an ip address in the private 169.254.x.x range (not available on the open Internet) and permanently assign it to the printer. it will also set up a static route to that address in the computer’s printer configuration
- turn the dhcp server back on by turning on the dhcp server by
connecting your cable/dsl modem or dhcp to the network. because the hp now has a permanent static ip address, it will
no longer try to use dhcp server to get an address
- install the software on the other computers on the network who will be using the printer. the installation software will discover the hp printer at the 169.254.x.x address, and will add the static IP address in each computer’s printer configuration
Note: if the installation cd will permit you to change th private ip address from 169.24.x.x, it's better to set it on the same range as of the ip address given by your dhcp server (for example your dhcp server provides ip addresses starting from 192.168.1.100-192.168.1.250, set the printer's ip address to 192.168.1.59-below or any ip address that will not compromise any ip addresses that were already being used by your other devices)
hope this'll help you but if you'll have other concerns just ask me.
ciao!
Jun 28, 2008 | Computers & Internet
Konica Minolta Di3510 AllInOne Laser Printer Logo
70 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
carpediemweb
Level 1 Expert
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
