1.Check the device's battery level for at least two bars of strength. 2.If the battery level is low, charge the battery. 3.If the issue is not resolved, remove the back cover. 4.Remove the battery. 5.Wait 10 seconds. 6.Press and hold the W key. 7.While pressing down the W key, re-insert the battery. •The device restarts and after approximately 15 seconds, the 'Recovery' screen appears •Release the power button but *continue holding the home button*, for another 30 seconds. Step Thanks
Dear Allen
Im strongly recommend you, buy a new original charger otherwise you can damage your headset.
The red light you saw probably because your charger is not compatible.
This is the Charge Coupled Device. Its a part that would need to be replaced by a technician. There is no way to explain to you how to get to it or how you could order this part. Your local canon dealer should be able to help with this problem.
On your Blackberry, navigate to Options,Bluetooth,Hit the cursor, Select Options, Set Discoverable to Yes, and save.
Make sure your Plantronic is in pairing mode.
On the Blackberry, hit the return key, add device, Search, Pllantronic will be listed on the blackberry as found. Select it, and add the password which by default is 0000.
i jus need the owner manual for plantronic discovery 925, the dint send me the manual,i have bunch the bluetooths but a want to try this,if you can help me send me 1 copy is ok if not is ok to , i not gonig to $39.00 dolr for the manual, idont want tecnical suport like a say i just need the owner manusl, thanks,ifo you want to charge $39.00dlrs for the manual i prefer buy new plantronic 925 for anohter $10.00 dlrs ,thank any way
