Question about Fisher Price Toys
Tukwill only go foward or reverse
I have an old power wheels truck I has two forward speeds and one reverse truck only go forward one speed with no reverse or if you switch battery conections it will only go in reverse with no forwards speeds it has three rocker switches 2 6 pole and 1 4 pole have replaced both 6 poles with no change
Anonymous
SOURCE:
Anonymous
  • 52 Answers
SOURCE: hampton bay ceiling fan
This should do the trick. Good luck and make sure the power is off.
L - Orange, 1 - Black, 2 - Yellow, 3 - Purple
Posted on Jan 29, 2008
Gene Pitts
  • 159 Answers
SOURCE: motor on ly runs on high speed
Hello rhett700, you have crossed a wire connection on the switch or your reostat is shorted/bypassed. If need be contact 'www.minnkotamotors.com/index.asp' ask for ext#406 ask for Dave. Have your model & serial # on hand. He is a good guy. Merry Christmas.
Posted on Dec 05, 2008
Anonymous
  • 19 Answers
SOURCE: Peg Perego Gator Ride On Toy
I had a peg perego gator hpx that was soing the same thing and I replaced both the high low switch and the reverse switch.
I found them at this website http://www.shopjandl.com/kids---baby-ride-on-toys-peg-perego.html
hope this helps
Posted on May 02, 2009
Anonymous
SOURCE: Motor Wiring
Two white wires are for the electric brake.  When the wheelchair is turned off while on an incline, the motors automatically lock up, preventing the wheelchair from rolling backwards.  The white wires disengage the electric brake when power is applied.
Posted on May 05, 2009
jamie
  • 1810 Answers
SOURCE: I need a replacement 6 pin rocker switch for
try electrosonic if in canada
they carry wide range of eltronic parts
but a simple 6 pun rocker can be bought ar radio shack or local electronics store
just remember if you need it to auto center it's easy to find if you want it to stick 1 way or other then you will have to modify the switch
Posted on Jul 07, 2009
Husqvarna problems
Question is unclear because reverse slower than forward, for safety, is normal as long as pto...blade is running full speed. Please provide more background & overview detail to validate an actual malfunction requiring corrective action. Thank you.
Sep 06, 2014 | Husqvarna Lawn Tractor Gth26k54t Owners...
Kid traxs corvette has reverse no foward speeds
do both wheels spin in reverse? if not you have a bad motor, replace the motor in the wheel that isn't spinning and that should resolve your issue
Nov 08, 2013 | Toys
No foward gears
its tranny internal failure (drum and clutch)
Nov 05, 2013 | 2005 Ford Expedition
Does not operate in reverse
If the vehicle will not go in reverse, but works in both low and high forward speeds you most likely have a bad shifter switch.
The shifter switch is only available in a shifter assembly found here: http://www.mendingshed.com/j4390-9209.html
Replacing the shifter should get your Power Wheels running correctly.
Thank you,
Colleen
Customer Service
MendingShed.com
800-339-9297
Mar 26, 2013 | Fisher Price Power Wheels Barbie Mustang...
Transmission
if its a three speed automatic (3t40) needs overhaul bad forward housing in trans
Aug 23, 2009 | 1997 Pontiac Grand Am
Rally PRIDE 3-WHEEL SCOOTER
Sounds like you have a bad throttle pot. You`ll need to check the resistance on it or take it to a dealer.
Dec 29, 2008 | Pride New Mobility Rally 4 Wheel Scooter
Power problem
throttle pot or loose hex nut that holds the actual forward and reverse paddle, may be slipping
Dec 20, 2008 | Pride New Mobility Rally 4 Wheel Scooter
Sounds like the gears are stripped. If a bunch of teeth are missing, only the high speed gear will spin the gears fast enough to move the gator forward. I just bought a used one and found it pretty easy to tear apart and diagnose as similar issue. The gear boxes, located inboard of each wheel contain plastic gears and strip relatively easy if the shifter is moved , during motion from forward to reverse.
Aug 11, 2008 | Toys
PEG PEREGO JOHN DEERE GATOR
Problem #1:If you have taken the high speed safety device off the stick shift(small red plastic block screwed on below the yellow stick shift housing) then your high/low speed switch has gone out. There are two motors(one on each back wheel) that both have to come on when in high speed. Only one comes on for low speed. It is the switch under shifter that is not spring loaded. hi/lo switch #MEPU0002 available at www.tigerimports.net for $11.00 plus $2.00shipping That is where I got mine.
Problem #2: Sounds like you need hi/lo switch and possibly forward/reverse switch too. Before buying forward/reverse switch try putting a little grease on the white plastic assembly that engages the forward/reverse switch between the top piece and the piece that pushes down on top of the switch. Sometimes they just stick enough to stop switch from depressing. It is the switch under shifter that is spring loaded.Forward/reverse switch #MEPU0003 $11.00 plus $2.00 shipping @tigerimports.net
Jul 19, 2008 | Toys
Toys Logo
Top Fisher Price Toys Experts
Marvin
Marvin
NOEL
NOEL
yobo007
yobo007
Are you a Fisher Price Toy Expert? Answer questions, earn points and help others
