It sounds like the magnetron may have
either failed or is not being supplied with the extremely high
voltage required to run it.
YOUR
SAFETY IS PARAMOUNT
This is a job for a professional but if
you are safety clued up, here's instruction.
Make sure the !!!!any
capacitors are discharged!!!!! before attempting any sort of
repair.
Check the door interlock switches first then the high
voltage diode with either an AVO model 8 or moving coil meter on high
resistance range for short circuit, (DVM's won't show the fault!),
the capacitor can fail and go short circuit, the feed fuse on the
primary of the high voltage transformer and then finally, the
magnetron is best checked by substitution.
Hope that helps.
YOUR
SAFETY IS PARAMOUNT
repair.
Hope that helps.
YOUR
SAFETY IS PARAMOUNT
Make sure the
!!!!capacitor is discharged!!!!! before attempting any
sort of repair.
high voltage diode with either an AVO model 8 or moving coil meter on
high resistance range for short circuit, (DVM's won't show the
fault!), the capacitor can fail and go short circuit, the feed fuse
on the primary of the high voltage transformer and then finally, the
Hope that helps.
Make sure the !!!!capacitor is
discharged!!!!! before attempting any sort of repair.
Check
the door interlock switches first then the high voltage diode with
either an AVO model 8 on high resistance range for short circuit, the
capacitor can fail and go short circuit, the feed fuse on the primary
of the high voltage transformer and then finally, the magnetron is
Hope that helps.
voltage required to run it. The turntable motor is supplied from the same point as the magnetron transformer.
Check
the door interlock switches first then any fuses. The high voltage diode with a moving coil meter on high resistance range for short circuit, the
Hope that helps.
Check
Hope that helps.
Check
Hope that helps.
Check
feed fuse on the primary of the high voltage transformer and then
finally, the magnetron is best checked by substitution.
Hope that
helps.
The magnetron may have either failed or
is not being supplied with the extremely high voltage required to run
it.
Make sure the !!!!capacitor is discharged!!!!!
switches first then the high voltage diode with either an AVO model 8
on high resistance range for short circuit, the feed fuse on the
Hope that helps.
