I replaced the WD 160GB HD with replacement WD 160GB HD. The replacement has been formatted FAT32 and the drive jumper is in the CS position. The DVDR won't recognize the replacement HD. Settings | HDD is dim and not selectable. If I try to record anyway I get "Cannot record on this HDD E 49" error. Any thoughts?
Unable to FORMAT the HDD in the device? Perhaps remove the drive - hook it up to a working PC temporarily, and using a partition software program or you could burn a CD (I use PartitionWizard), delete any or all partitions on the new 160GB WD and make that drive UNALLOCATED and UNFORMATTED. Apply the actions as needed - only to that drive (this will at least allow your unit to recognize it properly). Once done, remove the drive from the PC, and put it back into your recorder - see if it recognizes it this time, then try and format it (in accordance with the type of file system the unit uses - which may differ from that of a PC). Replacement drives should be formatted to suit the unit they are intended for AFTER they are fitted, not before. Otherwise you run into compatibility problems (e.g. the drive won't allow recording/doesn't read etc., but might work in a PC). If this is the case, it may explain greyed out options and not being able to record to it. If you still have the original drive, check the jumper setting to be sure. If both old and new are set to CS - leave them as is - don't change that.
SOURCE: Dubbing from DVD to HDD
You did get this from me but, if you are trying to dub a protected dvd, the dub option will be greyed out. Non-elegant solution: use another device to play the dvd and run it as input into the DVDR. You won't have the menu items but you will have the video.
