This problem happened after a sudden power loss to my house.
Hello Walter, thank you for your post!
An error code E57 could mean a number of issues, but primarily that the motor is overheating or a higher-than-usual motor current caused by other issues. Typically, an experienced technician would remove the belt to check the motor and motor pulley to ensure all is in working order first. Their next step would be to check the tub pulley and tub bearings. Last items they would examine would be the drive motor and speed control board by ohm measurement. Once the tech has ruled out a number of possibilities, he or she can pinpoint the exact problem and the necessary part to fix the issue. Since parts can often be quite costly, I would personally recommend reaching out to a qualified tech who can accurately diagnose the issue your washer is experiencing.
Hope this proves helpful!
SOURCE: Error code E10 on the
E10 is a timeout code. I found the answer on google by refining my search criteria. The tap was not turned on enough for the washer to fill up in time before the timeout was reached. After restarting the washer and turning the tap on further, the washer cycle completed without error.
SOURCE: error message E31 on Electrolux I-touch front load washer
Hello kleveille
Welcome,
You said, your machine comes on but will not start
I need the model number to start to help you???????????????????
huuum
SOURCE: Stops at spin cycle
Open the lid to the washer and let it down gently. You should hear a click when the lid closes. If you don't hear it, the lid switch might be faulty and this will prevent the washer from going into spin. Not an expensive repair.
http://tclaundryrepair.com/
SOURCE: error codes for Electrolux front load washer EWF 1087
E40 error is door interlock faulty, could be the lock or it could be the pcb u have to test them.
SOURCE: Electrolux front load washer door won't
First try to reset the lock unplugged the power machine for a few (10) minutes (maybe release the interlock door switch). If this work, them its possible that you need door latch replacement.
To do it, turn
off power, unplug at the mains. Drag the machine out so you can see
the back. Remove the 2 screws that hold the top on, pull back or tap
the top forward (depending on the model) to unclip it. Peer inside.
You will see the door switch inside the chassis exactly in line with the
door handle on the outside. See if you manually make the mechanism
release, or if you have a stubby philips screwdriver, you can probably
unscrew the switch complely.
Keep us updated.
Good Morning friend, thank you for your post!
From my understanding your Electrolux washer is not starting no matter what buttons are pushed. This could be a possible problem with your keypad or control panel. I noticed that you have already performed a reset and that was done when you unplugged your washer for 15 minutes. I would now recommend having a technician out to perform a diagnosis. In order to do so you would need to disassemble your washer and test each component to make sure they are working properly. The technician would have the appropriate tools needed to do this accurately. If you need some assistance locating a technician you should be able to visit the manufacturer's website for additional assistance. I hope this information is helpful for you. -Matt
Hello ajwalz - Typically E26 indicates that there is a recirculation pump relay. You will need a certified professional to check the wiring between the main control board and pump/recirculation board to determine which part has to be replaced.
