SOURCE: universal remote
What are you trying to do with the one that came with the set? Remember, you must have a good source for a signal such as antenna, cable, etc, in order for the set to work properly...accordianman
SOURCE: spongebob remote
Contact Emerson Electronics customer service to acquire a replacement remote for this set, as this set does not have the extensive circuitry inside to duplicate the functions of said remote...accordianman
SOURCE: Spongebob tv remote
contact Emerson parts supplier's number at 1-800-321-6993. They have the replacement remote control for $29.99.
Try also here
SOURCE: Emerson Spongbob tv broken remote...cant change input?
Then the only way to reach your tv is through coaxial antenna port. So you can buy an rf modulator ( very cheap) and connect your red yellow and white cables (rca cables from a dvd, game console etc) to the modulator then connect the modulator to your antenna with a coax cable. This worked for me.
SOURCE: I have a spongebob TV
Please contact Fox-International.com for replacement remote. it's where I got mine or
just get a generic remote and any tv shop .
Actually I found there are several remotes that work. The first is the Bright House networks remote, the larger one that they provide you when you get digial service.
The second is The Universal Remove Control by GE. It's numbered 24944 in the upper right hand corner of the paper. It's sold for $4.94 at Walmart in the checkout area...
I found that manually inputting the code for the remote doesn't work. You have to do a search for the code using their method...on this particular remote from Walmart, its hold the setup button down until it lights up, then press and depress the TV button...then press channel up until the TV changes channels. It worked once, but I just kept going, the 2nd time it worked, then I pressed the mute button [to keep the code] and it works...you simply press input and it switches to AV.
I have to admit I thought it was ridiculous that you can't use this particular TV without the remote, but I was happy that I went through the effort the first time to keep trying remotes...
This is the first kids TV that I have found that you can't find the AV channel by going through the channels AND you can't hook up two items to the AV outlets because you have to disconnect the back or front ones, to use the other....PLUS it only comes with a dual AV outlet, instead of the 3 plugs [red, white, yellow] only has the white and yellow.
Thanks for contacting Fixya.
