Usually, the TomTom GPS doesn't start up because the battery is (very) low. Have you tried charging the battery (for a while, while not using it) before trying to start it up again ? You can do it using the car charger, or via the USB port on your computer (or through a power adapter).
Another common reason why the TomTom doesn't power up is because it was not shut down "properly". If you manage to get the battery charged (fully, before starting it up), it should resolve the problem. If not, e.g. the screen freezes after powering up, and doesn't go further ... consider doing a "reset" ... ( use a pin to press the "reset" hole ) ... and it should shut down and boot up again (properly). Make sure you do all this while the battery (fully) charged. [ The device uses the battery for power ... so, if your battery is not fully charged, plugging it into a power source may not help ].
The last possibility ... your battery no longer holds a good charge... even after you've plugged it in for a few hours. Hence, the device has no source of power. You may wish to have the battery replace first.
My 2 year old TomTom gps Via 280 will suddenly not turn on
Testimonial: "please connect it to the charger and press and hold on/off button for 15-20 seconds. it's a reset of your device if it doesn't help it is hardware issue or please check if your charger is wrking fine (please connect it to the pc) if the battery is dead it should start anyway"
Can you please elaborate / add details ... as to how far you are able to get before it becomes "now working" ? and what is happening ? e.g. can you power it on ? does the navigation application load / start up successfully ? etc.
Touch screen not working
hi.
solution 1 please hold the on/off button for about 15-20 seconds, it should make a hard reset, (when it's connected to the charger)
solution 2: is your charger working fine? try to connect it via micro usb cable to your PC
