SOURCE: how do I install my dell dj gen 2 on windows 7 ?
You must first install the driver, don't plug in the jukebox until you rdone with this, then install the dj explorer v2 and then connect your DJ. I really have had no problems whatsoever except I had to use virtual XP to mess with my playlist. email me if you have any problems.
SOURCE: My Dell Pocket DJ Sofware in not compatible with
Not compatible or not working well with windows 7?
(making a program work with windows 7)
Maybe, It doesn't work because the driver/application you installed is
for other versions of operating system. I am also using windows 7 like
you so don't you worry, You can still use your old installer/driver from
other versions of operating systems. Just remember that before
installing any program in a windows 7 Operating System Computer, Use
"troubleshoot compatibility". Right Click the Icon of your program
installer/application first, then choose "troubleshoot compatibility". This will
allow you to choose on what type operating system your program will run.
Just reply back if it still doesn't work.:D rate and vote for me:))
SOURCE: dell dj windows 7 driver
dont install the CD
open up as a folder when the autorun window popup
open of the driver folder
n just install the driver
i should work
it worked on my
