Remove from wall
SOURCE: Door Removal Sharp Microwave Model R-1611
The door comes off in a very simple way. Now...I'm speaking from the perspective of MOST microwave ovens. All you should have to do is open the door all the way to the left and lift straight up. The door has mounting pins that fit into a couple of hinge pin holes. If your oven is equipped with an upper panel grid, you may have to remove it, so the door will have more clearance. Putting the new door on is just as simple as lining up the pins in the door with the hinge pin holes and setting the door in place. Close the door slowly to make sure the pins are aligned with the holes properly. If not, the door will fall off while attempting to close. Let me know if this is helpful to you.
SOURCE: SHARP MICROWAVE R-1611 MADE VERY
20 A fuse inside m/w is out. The problem could be with HV condenser, one of the door switches shorted, computer board, magnetron. Needs technician to take a look on it.
I’m happy to help further over the phone at https://www.6ya.com/expert/vitaliy_f406165329c75ede
SOURCE: How do I get our Sharp Carousel R-1611 off the
You need to remove the hood (the grille cover above the microwave door and above the control panel) by lifting up on the bottom of the hood (the plastic should flex pretty easily) and popping it off. On the far left and right you should see two phillips screws, most likely bronze colored. You need to remove them (they are quite long) completely. The microwave will still be sitting on its support arms (which enter the chasis of the microwave from the rear). Once the screws are removed you need to lift the microwave up and pull forward - it should come off of the supports, but you might have to jiggle it a bit.
Don't forget to unplug the microwave and disconnect any ducting before lifting it off of its supports.
SOURCE: Trying to remove my Sharp R1830 microwave. We
remove the bottom of micro and filters / with a light look up wher the filter 's are on both sides and you will find a lever that when your pull it .. it will relace from back plate. make sure someone is holding it at this time so it will not fall on range below . ****
Testimonial: "Thanks so much...appreciate your help. The old microwave is now off and a new one in its place! Thanks again!"
SOURCE: how do I remove my sharp microwave mod # R1420B
Try these installation manuals, which may be close enough to yours to work:
http://www.microwavedisplay.com/r1490_r1600_r1750_r1870_r1871_r1872_r1874_hood_inst.pdf
http://www.microwavedisplay.com/tinseb371mrr0_install.pdf
We're
happy to help you with free advice and we'd appreciate your
thoughtful rating of our answer.
