Hi, I tried port forwarding and firewall setting rules, but didn't work! seems like I did wrong. Please help, thank you.
Go to official site http://support.dlink.com/search.aspx and take help or need any third party help Contact Us for GAME support and
D-Link Router Support for router.
SOURCE: how to port forward using Dlink DI-524 for Emule?
DMZ is a feature that is included on some routers but is not in Internet sharing software. A DMZ allows a single computer on your LAN to expose ALL of its ports to the Internet. When doing this, the exposed computer is no longer ?behind? the firewall. Port Forwarding vs DMZ A DMZ is far easier to set up than port forwarding but exposes your entire computer to the Internet. Sometimes TCP/IP applications require very specialized IP configurations that are difficult to set up or are not supported by your router. In this case, placing your computer in the DMZ is the only way to get the application working. Placing a computer in the DMZ should be considered ?temporary? because your firewall is no longer able to provide any security to it.
SOURCE: removing open port
Have you tried a full hard reset? This is done by pressing on the small recessed button at the rear of the unit. Of course all settings would revert back to factory defaults. Perhaps it may be to your advantage to notedown certain informatin such as your WAN IP configurations, security key etc.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
SOURCE: port forwarding
open up BitTorrent , then go to view , then select settings ,
next box open up network tab , in starting at point type in 6881. Then you want to open up you adsl router
to do this type in your IP address it should be 192.168.1.1 ( just type those number into browser )
When page appears login name and password just click login
Then go to advance and then to port fowarding and select user at bottom then click add . ( rule name can be the bittorent site you wish to use .. aka edonkey )
The TCP should read 4672 for all three and the UDP should read 9919 for all three .
Select apply then select tools ontop select save all
