Provided that your 2-way radio has the feature, there should be either a dedicated weather button or somewhere in the menus. Not sure what model you have. If it is a more advanced radio where you can set the frequency, the list of weather broadcast frequencies taken from NOAA are listed below. Two way radios are normally automatically programmed to one of these frequencies and usually require a push of a button.
Nationwide Station Listing Using Broadcast Frequencies
You must use a compatible programming cable and software (such as Chirp) to program the radio, and the frequencies must be within the radio operating range [400 - 471 MHz].
The Motorola GP3188 is programmable using Motorola CPS software, cable and RIB (radio interface box). The software is proprietary to Motorola and can only be obtained by authorized dealers and other qualifying entities such as Municipalities and/or large companies. The simplest method to get your radios programmed would be to visit your local Motorola dealer or send them to a service center via UPS/FedEx/etc
Sorry, but the XTN446 has only the 8 channels pre-programmed by the manufacturer.
Channels 8
Codes 121
Frequencies 446.00625 MHz
446.01875 MHz
446.03125 MHz
446.04375 MHz
446.05625 MHz
446.06875 MHz
446.08125 MHz
446.09375 MHz
Its so easy to use you really don't need a manual for the Uniden BC 142XL scanner.
Turn it on. Push the MANUAL button to stop it from scanning.
Push number 1, then push MANUAL again. This should leave you on
channel one.
Using the keypad enter the frequency you want to monitor, then push
E. Press REVIEW at anytime to see what frequency is programmed
there. If the review button flashes 000.0000 on the display, you might be entering an invalid frequency. Refer to the frequency coverage list below.
Push MANUAL to step to channel number two. Enter the frequency. Push E. Push MANUAL to step to channel three. Repeat this process until
all ten channels are programmed, or you've run out of frequencies to
enter.
Push "SCAN" to start automatically scanning the frequencies. The
radio will stop when it hears someone talking, and resume scanning two
seconds after the conversation has stopped.
Frequency Coverage:
20 to 29.7 MHz (10 Meter "Ham" Band)
29.7 to 50 MHz (VHF Low Band)
50 to 54 MHz (6 Meter Amateur Band)
136 to 144 MHz (Military Land Mobile)
144 to 148 MHz (2 Meter "Ham" Band)
406 to 420 MHz (Federal Government Land Mobile)
420 to 450 MHz (70cm "Ham" Band)
450 to 470 MHz (UHF Standard Band)
470 to 512 MHz (UHF "T" Band)
For a comprehensive database of active frequencies in your area, visit
The 92 does not have a separate/dedicated weather band feature, but you can program individual NOAA frequencies into it. Weather broadcast frequencies are: 162.400 MHz : 162.425 MHz : 162.450 MHz : 162.475 MHz : 162.500 MHz : 162.525 MHz : 162.550 MHz.
