Question about Magic Chef CYE2000 Electric Commercial Dryer
Dryer won't turn
Squeaking sound and now drum won't turn
Constant loud squeaking
Squeaking is normally caused by a bad bearing or a slipping drum belt.
Feb 28, 2015 | Dryers
GE dryer Mod # DWXR463EG1WW is squealing. Does anyone know what is wrong with it and how I can fix it?
Sounds like a rear bearing . remove the 2 screws from the top when you open the door . this way you can take the top off . When you take the top off remove the screws on the inner left and right on the front panel. disconnect the belt from the pulley and motor and pull the drum out . then you will see the rear bearing . cheap fix but can be a pain. good luck
Feb 16, 2013 | Dryers
Whirlpool LEW0050PQ electric dryer makes a noise.
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
sdfhywt4
May 22, 2010 | Whirlpool LEW0050P Electric Dryer
The dryer was squeaking when it was on but know it
possible worn bearing.the more wear on the bearing the lower the drum will be.the drum sounds like its rubbing the bottom of the dryer.check for black dust behind the dryer
Feb 20, 2010 | Amana Dryers
Kenmore Dryer 110 is making a loud squeaking noise.
Only a few things will make that noise. The squeaking is caused by a moving part having trouble turning while rubbing against a fixed part.
  1. The idler pulley is worn
  2. The drum support rollers are hard turning on their shafts
  3. The felt seals at the front or back of the drum is worn allowing metal to metal contact while turning
  4. An article has fallen into the housing around the blower wheel and the wheel is rubbing on it.
Listen for the frequency of the sound. The drum rollers and drum felts will squeak at the frequency of the tub turning. The idler pulley turns much faster as does the blower wheel. Knowing this will help pin down the cause.
The following link has valuable information on taking apart your style of dryer:
Sears Dryer Disassembly
Sep 20, 2009 | Kenmore Dryers
Dryer squeaks while drying sounds like drum rubbing on something
A squeak can also be a slipping belt or something caught between the drum bearings usually the front but could be the back one.
Jun 14, 2009 | Dryers
Squeaking dryer drum when operating
sounds like you need to adjust the motor that turns the drum to tighten the drive belt..... you do this from the back or bottom...
May 24, 2009 | Fisher and Paykel DG05 Gas Dryer
My Dryer squeeks while rinning
If it is a constant squeak no ups or downs then its the bearings in the motor that turns the drum. If the sound is not monotone, meaning up and down squeaks, then the drum is rubbing something foreign.
Nov 10, 2008 | GE DBSR453EBWW Electric Dryer
Dryer drum doesn't turn; makes a loud squeak sound
The problem is most likely your drum belt. Most run all the way around the outside of the drum, across a tensioner pulley, and around the motor.
This could be easy, or it could be a nightmare. Disassembly of the outer cabinet can be tricky. Some drums ride on pullies, while others slide on drum felts.
Your local appliance parts store can give you some guidance, and probably a few cards of qualified service guys. If you're mechanically inclined, and have a history of being able to take machines apart, AND reassemble without extra parts laying around, then give it a shoy. Otherwise, pay a pro, and save your Saturday.
Jun 25, 2008 | Dryers
DCXR463GA2WW Squeak
YOU MOST LIKELY HAVE A REAR DRUM BEARING FAILING. IT IS A SMALL TEFLON BEARING THAT SLIPS ON OVER THE REAR SHAFT OF THE DRUM AND INTO THE HOLE IN THE REAR OF THE DRYER. THERE ARE ALSO FRONT GLIDES THAT SUPPORT THE FRONT OF THE DRYER. OLDER DRYERS HAVE THE FRONT SUPPORTS UNDER THE DRUM SO THE DRUM RESTS ON THEM. NEWER G.E. DRYERS HAVE A PLASTIC RING WITH THREE TEFLON GLIDES ON TOP OF THEM AND THE DRUM HANGS FROM THESE GLIDES. REPLACE ALL OR SOME OF THE ABOVE PARTS TO ELIMINATE YOUR SQUEAK.
ON OTHER POSSIBILITY, THE IDLER PULLEY THAT KEEPS TENSION ON THE BELT CAN BECOME A SQUEAK MAKER.
Apr 07, 2008 | GE DCSR483EA Electric Dryer
Magic Chef CYE2000 Electric Commercial Dryer Logo
18 people viewed this question
Top Magic Chef Dryers Experts
Gene Pitts
jimorris77
Nathan Van Boven
Nathan Van Boven
Are you a Magic Chef Dryer Expert? Answer questions, earn points and help others
