Onkyo TX-SR876 Receiver Logo
A
Anonymous Posted on Jan 15, 2014
When I turn up the volume, my amp shuts off and goes on standby
Hooked up Klipsch VF-35 speakers via bi-amp directions
5 Related Answers
Anonymous
  • 67 Answers
  • Posted on Dec 24, 2008
SOURCE: Low Volume regardless of input
Front L/R and Surr back L/R are the termianls used for BI-amping
Check page 27 of the manaul
http://www.onkyousa.com/download/own_manuals.cfm?cat=Receiver
you can find it here
Gurudristi
Sachin
  • 98 Answers
  • Posted on Mar 09, 2009
SOURCE: I just hooked up my old Onkyo TX-8511 receiver to
Just check your speaker cabling again. Make sure that all of them are seated properly, none is touching each other or the body of receiver. Rewire if necessary..
Are you using banana plugs for connecting speaker or just directly. Some times even a little tiny wire touching the receiver could trigger the protect mode. Be careful, since protect mode is sometimes not fast enough and it could blown a few trasistors in the power circuit.
Otherwise, do your bose speakers play out load on other systems?
Gurudristi
Sachin
  • 98 Answers
  • Posted on Mar 12, 2009
SOURCE: Connecting NAD 314 Receiver\ preamp to Carver M-500t to speakers
Dear Tim,
Yes, you can connect your NAD as a preamp to the Carver power Amp.
Connect the NAD's pre-out to the input of the Carver Power Amp. You can then connect the Klipsch speaker to the Carver. Set the gain control on the NAD.
Now you should be able to control all the input and the main volume control from the NAD.
Anonymous
  • 144 Answers
  • Posted on Apr 17, 2009
SOURCE: TX-SR506 Bi-Amping
If you select bi-amping the device will use a second amp for your rear speakers, this indicates that in your setup menu you probably have deleted the rears (set to None). Try to find the settings for your rear speaker in your setupmenu and see if they are selected in normal operation.
If all fails, see if you can reset teh device back to factory settings, sometimes software can get confused after using for a while. Resetting should than fix most problems.
You can also check and see if there is maybe a software update available for your device, loading and installing is explained in either the file or on manufacturers site.
mbalixabiso
  • 3 Answers
  • Posted on May 11, 2009
SOURCE: Reciever shuts off
Hi there
May I ask how many watts can your reciever handle ? And how many watts does your speakers need in order to be powered up (input). The two speakers you have installed might be too powerful for your reciever to handle. You might have to down grade to less powered speakers. All in all you have an excellent product there good choice...
I have a Pioneer VSX 823 - K, and when I hook up my Klipsch HG-12 300 watt subwoofer to it, the receiver is prone to overheating or just shutting off with too much bass. Is there a fix to this?
This is receiver thermal going in protect issue and has no bearing to your sub, The sub has its own power amp and not supplied by the receiver. Thermal module may be bad. See a tech.
Zx750.1 kicker amp cutting out
Also check your fuses. there may be a fuse for the in-tank fuse.
1helpful
It can be possible to bi-amp a pair of Klipsch RB-81 with this receiver for stereo listening, and if yes, how...
Bi-amping indicated that you have two amps, one for the tweeters, adn another for the woofer, in a two way system. If you don't have two seperate amps, you can use the speaker A & B outputs to run seperate speaker llines to each set of speaker inputs, but that will not be true bi-amping. Another alternative is to use jumpers to connect the speaker inputs together, this not needing seperate amps. Here's a link to the owner's manual:
http://www.manualslib.com/manual/359882/Klipsch-Reference-Series-Rb-41-Ii.html#product-Reference%20Series%20RB-81%20II
14 speakers hooked up to home theater reciever,shuts off .5 vol
Try less speakers.
The impedance will be to low for this amp.
Regards,
Gerard
Dear Tim,
2helpful
Sony amp str-db940 - protection
Somewhere in your speaker wiring, you have a shorted wire. This short can be as simple as a single strand of wire touching the other terminal on one of the speakers.
With a bright flashlight, look carefully at the back of the receiver and then the speakers for any loose strands.
Shuts off
The unit is protecting itself from a high current situation on the output amps. Either you have a bad speaker or an Amp that is getting ready to give up the ghost. Check your speakers with an Ohm-meter for proper readings (ie 4Ohm speaker should read 4 ohms)
3helpful
3answers
Onkyo 705 receiver shuts off at higher volumes
I had this same problem and it turned out to be a twisted kink in the speaker wire. Run a sound check to each speaker separately (from your receiver menu) and turn each one up until the receiver shuts off. Check the wire to the speaker that caused it to shut off and make sure the +- ends are not touching each other at either end, and that there are no twists or kinks along the way.
B speaker shuts unit down...
You will have to disconnect the B speaker wires and disconnect the speakers and measure the wire with nothing on the wires as it sounds lkike you may have a pinched wire or shorted wire somewhere, or the B speakers one or both are bad. I am leaning towarods the shorted or pinched speaker wires. I say this because if there was an amp problem, it would happen on the A speakers too as the speaker A and B is nothing more then a switch to turn the desired speakers on and off. Good Luck
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Grand Canyon Tech
Grand Canyon Tech
John
John
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
