Re: I would like to know which foot attachment you use on...
You would normally use your standard sewing foot, or usually called your "zig-zag foot" for sewing on stretch fabric, just as you would woven fabric. Or, you can buy a "walking foot" sometimes called an "even feed" foot that will help the top and bottom layers to feed more evenly together. If your model has an adjustable presser foot tension, (adjusts the "drop" strength of your foot that you will feel when you raise and lower the presser foot lever) you may want to decrease it some, and test a scrap to see how well it feeds the particular fabric you want to use.
You can also use an "over-edge foot" with certain utility stitches to give a 1/4 inch seam that looks similar to a serged seam.
You may want to find a book (I like to borrow them from my library) that shows various sewing machine feet and what they can be used for.
Don't forget to use ball point sewing machine needles for stretch fabrics. Good luck with your project!
You may want to change the tension slightly to make sure the top & bobbin threads meet in the middle of the fabric. Use a heavier needle and thread. Increase the stitch length. And possibly change the presser foot pressure or use a walking foot, roller foot, or teflon foot. If the pressure is too heavy, the presser foot may "push: the top layer of fabric in front of it so the top fabric is slightly stretched or puckered.
Did you pre-wash the fabric? Sometimes the finish applied at the factory causes problems. Also, be sure to use a ball point needle on knit fabric. Sometimes, using a walking foot, teflon foot, or roller foot will help the fabric move smoother through the machine. It could be that your machine is experiencing a problem with the back-n-forth movement of the stretch stitch. Otherwise, here are more guidelines to review:
The top fabric is stretching as you stitch? Most likely, the presser foot pressure is too high. There is usually an adjustment for the pressure that the presser foot applies to the fabric. You can also try using a roller foot, teflon foot, or walking foot that will assist the fabric to feed through the machine.
Most likely a Singer presser foot will not attach to your Bernina. They are not interchangeable.
You can also probably use something like this: https://www.youtube.com/watch?v=JOImaKwv4fU but you need to purchase a snap-on shank adapter for your Bernina, like this: http://www.ebay.com/itm/PRESSER-FOOT-SNAP-ON-SHANK-ADAPTER-BERNINA-OLD-STYLE-530-1630-0062617000/282290526069?_trksid=p2047675.c100005.m1851&_trkparms=aid%3D222007%26algo%3DSIC.MBE%26ao%3D2%26asc%3D40807%26meid%3D4fe9a7b6fca84bb3adef4f466cc8776f%26pid%3D100005%26rk%3D2%26rkt%3D6%26sd%3D401187382421
Or, are you talking about the presser foot? Bernina #033? You can usually find a replacement through eBay, or even purchase a snap-on shank and pick up a snap-on buttonhole foot. But, if you have another zig-zag foot or open-toe presser foot, you can probably get by with using it as long as you can see your marks on the fabric when you stitch.
If you are actually referring to a buttonhole attachment like what is available for new machines, you may be out of luck. Probably not any available for this older model. The automatic buttonhole attachment usually has a sensor that your machine does not accommodate and the buttonhole attachments have a different shank that will not work on the older machines.
However, the buttonhole dial on your machine should work just fine. You just need to do more pre-work, ie measuring the button and marking the buttonholes on the fabric before stitching them. Even if the machine is only a zig-zag, buttonholes can still be done on them. Just be sure to practice a few buttonholes on scrap fabric before trying them on your garment. Get the stitch length so the zig-zag stitch has no gaps between threads but also does not overlap the thread next to it. Also, check that the tension does not cause the fabric to pucker (be sure to use a stabilizer between the fabric to prevent the fabric from stretching or distorting).
You could unconsciously be holding the fabric back when it is feeding through the machine so you are building in stretch. Or, the presser foot pressure could so high that the presser foot is actually pushing the fabric in front so it is building in stretch. If you have a presser foot pressure adjustment on your machine, you might try loosening it some. It would be helpful to use a roller foot or walking foot (if you have one) that will not impede the movement of the fabric but instead help the fabric move through evenly. Also, lengthen the stitch length and add a zig-zag. That will give the garment some give, but if the fabric does stretch, it will also go back to flat once you remove it from the machine. How to Sew Knits and Stretch Fabrics with Sewing Machine Sewing Stretch Fabrics Sewing with Stretch Knit Fabric Part 2
If the fabric is puckering when you sew, it is most likely because the thread tension is too tight. Make sure you are using a brand-new needle compatible with your fabric--using a 70 or 80 needle and a lighter weight thread may work better as a 90 or higher needle is big enough that it can stretch the fabric before penetrating it, causing puckering.. Puckering also occurs more frequently when sewing light-weight fabrics and may necessitate using a walking foot or a stabilizer to help give the fabric more body as it is stitched (wash-away stabilizer would probably be good when sewing washable fabrics). Another thing that may cause puckering is when the bobbin is wound at a fast speed. Slowing down when winding the bobbin will reduce the amount of stretch added to the bobbin thread. If it is stretched going onto the bobbin, it will shrink back up when it is stitched to your fabric. Also check whether your machine has a presser foot pressure adjustment. The pressure should be lighter when sewing finer fabrics, ie silk, and heavier when sewing thicker fabrics like wool or denim.
I'm a bit confused, this isn't a serger machine as far as I can see. So do you mean an overcasting foot where you sew a XXXXX type stitch along the edge of the fabric? The overcasting foot just helps you to line up the fabric edge and sew over it neatly.
If you are wanting to sew knit fabric then you just need to use a small zig zag stitch and a ball point needle to put elasticity into the seam. Or your model may have a stretch stitch, where the fabric is moved forwards and backwards during the stitch formation to add some elasticity.
Sewing elastic stretched onto fabric is a bit different with a SM, can be fiddly and hard to keep everything lined up nicely and stretched. Some machines have a little device which clips onto the needle plate in front of the needle that you can feed elastic through and tighten it to tension it, then just use a three step zig zag stitch to seam over this onto your fabric. But I don't know if Necchi has such a thing, your needle plate would need holes in front for it to clip into. Elna had these on their swiss machines in the 80's but haven't seen a similar device for a while.
Hope I've answered your question and not completely misunderstood your problem. Purchasing a manual is often the best way forward when a machine is unfamilar. Or www.sewing.about.com is great resource.
Do you have a walking foot attachment? Also, called an evenfeed foot. You can also try using tissure paper under your fabric as you sew for a quick fix.
