I ordered a new lamp for my Sony KDF-E50A1 TV. No problem opening up the outer door and taking out the inner door. All I have to do is hook my finger around the loop of the bulb housing and lift up and out. I have no problem lifting it up, but it will not pull out. I am afraid to break it. I can see the lever pulling up when I lift up on the loop, but it just won't pull out. What do I do?
SOURCE: Sony KF-60WE610
Some of the ICs on the power supply block are damaged. This can possibly due to high voltage or defective IC. What you can do now is to get a new PS block. If you can get me the part number i can help you find it..
SOURCE: Sorry did not know if I posted this correctly or not.
I just brought my kf-42we610 sony authorized service-tv went black would not turn on-I was infromed Sony knows about problem with the fan in back -gets way to hot and basically melts everything-they are fixing free of charge until march of 09
SOURCE: Sony KDF-E50A10
If the lamp is new it could be the ballast the one is supply high voltage for the lamp you can order that ballast from Sony
Check the lamp if is not damage any where
Cheers
SOURCE: Red light blinking 3 times on Sony xl2400 lamp replacement
I solved this problem myself. You have to continue working with the housing until the connections meet just perfect. It was extremely frustrating but in the end I got it to work.
SOURCE: I have a Sony KDF-46E2000.
I have the same problem I was told that the new bulb that I put in might be faulty.
