Every time i try to hard reset it keeps going into safe mode (emergency calls only) ???
You can find more information about hard reset here
Factory Hard Reset
LG E739 hard reset
LG T-mobile myTouch E739 reset
If you can't recall your unlock Pattern:
When the phone is turned off, press and hold the Power/Lock + Volume Down.
After 3 seconds press Back and Menu keys.
WARNING: If you perform a Hard Reset, all user applications, user data and DRM licenses will be deleted. Please remember to back up any important data before performing a Hard Reset.
Source: http://www.hard-reset.com/lg-e739-hard-reset.html
SOURCE: Need to 'hard reset' my Samsung Galaxy Europa
I attempted the above in order to hard reset my Europa i5500. However, it didn't work, and instead just went back to the "enter address/password" screen. I've attempted to connect to Kies, but to no avail, Kies doesn't register that the product is plugged in. I can get the phone onto download mode and emergency download mode, however neither are helping me much. Any suggestions?
SOURCE: why does lg vu go into emergency call mode
You accidentally locked it up, call your provider and follow the steps they give you
SOURCE: Can't Reset to preactivated factory stage(emergency call screen?)
go to itunes. when plugging in to computer hold down the home key it should restore factory settings. i called apple.
SOURCE: A very close friend of mine recently bought a new
You may have a loose connection in your phone that dislodges the SIM card when you open the flip, or your SIM wasn't correctly seated when you installed it on your phone.
Emergency Mode generally comes up when there is no SIM in the phone, or when there is a software error. If pulling out and reinserting the SIM doesnt work, you may have to visit an authorized repair center in order to resolve the issue.
SOURCE: lg 420g- When I try to make a call. I get "
Remove battery and SIM card, then put them back in. Power up phone and try to make non-911 call. It worked for me. Godd luck!
