Sir i have z560 model lenovo pc i5 intel core inside. its screen display is blurry from last two days. kindly help
SOURCE: My Lenovo y510 display is blurry. Sometimes it
Need a replacement soon.
If you want a temporary solution for your eyes, use a regular monitor, and plug it to the laptop
Don't forget to rate if this answer helps
SOURCE: Require Audio Driver for Lenovo 3000 N200 type 769 dual-core
I purchased a used lenovo laptop 3000 n200 0769 intel centrino core 2 *** 2\r\nwithout any driver for audio, network, camera, vedio, and other drivers...
from where can I load them
pls. help me
SOURCE: cost of display ic for Lenovo 3000 Y410 Laptop
If you haven't fixed it yet. The best price I can do is $82.00.
SOURCE: Dear sir, kindly help me
The Lenovo OneKey Rescue System is an easy-to-use application that can be used to back up the data on your system partition (C drive) for easy restore when required. You can run Lenovo OneKey Recovery under the Windows operating system, and the OneKey Rescue System Attention: In order to utilize the features of the OneKey Rescue System, your hard disk already includes a hidden partition by default to store the system image file and OneKey Rescue System program files. This default partition is hidden for security reasons and is the reason the available disk Using Lenovo OneKey Rescue System (Without Windows operating system) In the event that the operating system cannot be loaded, follow the steps below to access OneKey Rescue System. • Shut down your computer. • Press the key next to the power button to launch OneKey Rescue System. Within the program, you can choose to restore your system partition to the original factory status, or to a previously generated backup. Notes: • The backup process and creation of recovery discs may take some time, connect the AC adapter and battery pack to your computer. • After the recovery discs are burned, please number them so that you can use them in the correct order. • Computers without an integrated optical drive support the creation of recovery discs; however an appropriate external optical drive is needed to physically create the recovery discs. Note: The recovery process is irreversible. Make sure to back up any critical data before using the recovery feature. If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response. Happy Holidays! Thanks, Joe
without starting the Windows operating system.
space is less than it claims. The exact available hard disk space depends on the file size of the
mirror image file (based on the size of operating system and preinstalled software).
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
SOURCE: lenovo z560 cpu overheating problem solved
OverheatingWhen the CPU overheats then it will shut down (i.e. thermaloverload) and won't boot up again until it has cooled down. If this is theproblem is not fixed then the CPU will eventually fail.
A faulty fan causes the problem or the fan and heat sink assembly are cloggedwith dust.
Check the CPU fan to see if it spins freely, if not replace the fan.
If the fan and heat sink is clogged with dust the remove the dust and make surethe vents are clear and dust free. Use a small brush and can of compressed airto do this.
