Question about Flowtron LE-900 Leaf-Eater Mulcher
Flowtron LE 900, The Ultimate Mulcher, just quit
I found that the new cutting string had wrapped around under the spool. I cleared it. I checked my circuit breakers. The machine just won't go back on. Is there an internal breaker to reset? Is there an internal fuse?
  • Anonymous May 28, 2009
    I fixed my own. So far. Tilted it up and found the remains of a reset button by the label on the switch side. It goes. Doesn't like sticks, though; they tear up the string.
I found a reset switch on the leaf-chipper. I was then careful to fill it more slowly, and to keep out sticks and clumps of wet leaves.
Posted on May 29, 2009
6ya staff
SOURCE:
The motor burned out after one year of use. It was bought in Oct 2009. This year in Oct. it burned up in about 10 min. How can I get a replacement motor? I took it apart, cleaned it, reassembled it...
I would recommend contacting the manufacturer. The warranty was 1 year. If you are at 13 -14 months, I would ask Flowtron for some help in getting it replaced. Sometimes manufacturers are willing to split the cost of a repair that is near the warrany end to help keep a customer satisfied. It is worth trying.
Good luck.
FLOWTRON OUTDOOR PRODUCTS
15 Highland Avenue
Malden, MA 02148
Telephone (781) 321-2300
Fax (781) 324-8403
Parts & Service: service@flowtron.com
Sales: sales@flowtron.com
Dec 07, 2010 | Flowtron LE-900 Leaf-Eater Mulcher
I need a replacement spinner assembly for an older Flowtron Leaf Eater -- 800, I think. Any suggestions?
Go to www.flowtron.com. There you can find the parts you are looking for like ler-500 spinner assembly for $20.95.
Good Day.
Nov 18, 2009 | Flowtron LE-900 Leaf-Eater Mulcher
Where could I get a replacement motor for a LE 700-1 flowtron
go to www.flowtron.com and call their customer service. That is what I had to do.
Good Day.
Nov 16, 2009 | Flowtron LE-900 Leaf-Eater Mulcher
What size is the line for replacement. Can't find
www.Flowtron.com is the website for this company. I saw some replacements strings Part# LER100 for about 5 dollars. I did some additional looking but could not find a size on the string but hope finding the website helps.
Good Day.
Oct 18, 2009 | Flowtron LE-900 Leaf-Eater Mulcher
Flowtron Leaf-Eater Mulcher LE-900F
Shot in the dark here. If the mulcher is tripping and needs to turned off then back on, it's defective and should be replaced. If the circuit breaker in your house panel is tripping, try to use different circuit on a 20 amp circuit breaker. If your using a plug that is controlled by a GFCI receptacle or breaker, move to a different plug. GFCI receptacles tend trip when motor loads are applied. These are my best guesses since I'm not sure what exactly you are reseting.
Apr 25, 2009 | Flowtron LE-900 Leaf-Eater Mulcher
How do you intall the cutting string on a Flowtron leaf eater?
I have an electric weedwacker which may be different. In the leaf wacker there are four small holes very near the center screw on the revolving shaft. These holes form two small tunnels. cut two pieces of line (10-12 inches) and stick one through each tunnel. Center each line, put the two ends together and poke them out through the small hole on the edge of the rotating shaft. You end up with two sets of plastic line facing out from the central shaft. Flowtron may be different. Good luck.
Mar 23, 2009 | Flowtron LE-800 Electric Leaf Shredder
Reload cord.
I just replaced my Flowtron cutting string. That screw in the middle comes off if you turn it hard enough. Then the spool lifted off. I took it to the hardware store to get the right gage string, and installed it like the old. It was curly though, and got caught under the spool when I used it. Then the motor quit and won't start. So I just posted that problem. ~ CarolK
Nov 13, 2008 | Flowtron LE-900 Leaf-Eater Mulcher
Circuit breaker
I was able to get a replacement 5 amp MB-1 push to reset circuit breaker for my Flowtron LE-900 directly from Snap Action http://snapaction.net/ for no replacement cost and no shipping/handling cost. No one at Snap Action enquired as to what it was for, age, warranty, etc. (their MB1 product description indicates it to have a lifetime guarantee). I just had to mail them the defective original breaker - took about 2 weeks to receive the replacement.
Brett
Oct 16, 2008 | Flowtron LE-900 Leaf-Eater Mulcher
Mulchers storage
when its empty you can store anywhere you like but when its full try and keep in open place due to smell that may burst from the mulcher.
Aug 27, 2008 | Flowtron LE-900 Leaf-Eater Mulcher
Flowtron LE-900 Leaf-Eater Mulcher Logo
409 people viewed this question
Top Flowtron Garden Experts
roeb
john h
Marvin
Marvin
Are you a Flowtron Garden Expert? Answer questions, earn points and help others
