Motorola Mobility H500 Wireless Headset Logo
Posted on Apr 09, 2017
Passcode reset for H505
The device has been added to my bluetooth menu and while it is on the phone is saying that the device is out of range or powered off when it is on. I know i paired it successfully but am not able to use it. Thanks for you help. I am trying to pair my moto h505 headset with my blackjack from att. I was using the headset on a pearl from verizon. the blackjack is asking for the passcode. I have tried all defaults for example 1111, 1234, 9999, 0000, etc. I have also used the last digits of my phone number and it still wont take it. I was wanting to know if there is a way I can reset the passcode on my bluetooth to make it work? Thanks!
5 Related Answers
Anonymous
  • 11 Answers
  • Posted on Feb 27, 2009
SOURCE: Pass code for verizon bluetooth
It should be 0000, unless they changed the code
Anonymous
  • Posted on Jul 22, 2009
SOURCE: How to connect SAMSUNG bluetooth headset SBH 650 to my Nokia e71
When the pairing process between the E71 and SBH650 starts, try immediately to hold down, or press every half a second, the central 'call' button on the SBH650 - to force the SBH650 to think it is pairing with a new device. It took me 5-10 min of playing about in a similar situation, but eventually the SBH650 cleared it's 'memory' and the '0000' pairing code worked with another telephone...
however, I have never managed to pair the SBH650 with OS 3.0 upgraded ipod touch 2nd gen.
Anonymous
  • 987 Answers
  • Posted on Oct 14, 2009
SOURCE: what is the passcode for the H505
yes try to use 0000
Anonymous
  • 713 Answers
  • Posted on Mar 11, 2010
SOURCE: I need a passcode for my motorola bluetooth h505
Hi,it seems you have problems pairing your bluetooth headset with your new phone in terms of the pass code,
Here is the passcode;
The default passcode for the motorola h505 is '0000'
Take care of yourself and have a nice day
Harrie
  • 6746 Answers
  • Posted on Jan 13, 2015
SOURCE: My Motorola Elite Flip Bluetooth will not pair with my new Samsung s5. Can you help me
page 19 and 20 of the manual tell you what to do if the flip won't pair. https://motorola-global-portal.custhelp.com/ci/fattach/get/634666/1370266396/redirect/1/filename/Elite_Flip_GSG_68017335001A.pdf
2answers
Bluetooth passcode
To find a bluetooth passcode click tis link bp
to change passcode click tis cp
to reset rp
  • Step 1 Look on the back of your headset or speakerphone for the Bluetooth passcode for the device. Typically the pairing code for headsets is printed on a sticker that is then placed on the underside of the accessory.
  • Step 2 Go into the Bluetooth menu on your cell phone to find the passcode for your cellphone. The Bluetooth menu for your phone is typically located under the "Settings" menu. In the Settings menu there should be an option to "Get code" or something comparable, which would allow you to find the code for your phone.
  • Step 3 Go into the Settings menu for your computer to find its Bluetooth passcode. Some laptops will randomly generate a new Bluetooth passcode for you each time you want to pair them with a new device. In that case the menu setting you're looking for is something like "Generate new pairing code."
  • Step 4 Look in the instruction book for your Bluetooth accessory if you cannot find the passcode attached to the device or in its menu. Many manufacturers will print the passcode for devices in their instruction book. If you still can't find the passcode, try using all zeros.
  • Read more: How to Find a Bluetooth Passcode | eHow.com http://www.ehow.com/how_5169210_bluetooth-passcode.html#ixzz0vcmCZd00
    My bluetooth does not work
    Hello
    What you have to do is to is to open the bluetooth menu on your phone and touch the bluetooth logo to put on the bluetooth radio.
    Highlight add a new device,your phone will search for bluetooth device that are within that range and when you see the name of your bluetooth device appear on the screen press next.
    Enter the bluetooth device passcode,this can be found in the device owners manual.if the passcode is accepted then press done.The pairing process between your phone and a bluetooth device is complete.
    BEST OF LUCK
    1helpful
    My HTC magic mobile Bluetooth is not working
    Hello
    What you have to do is to is to open the bluetooth menu on your HTC phone and touch the bluetooth logo to put on the bluetooth radio.
    Highlight add a new device,your HTC phone will search for bluetooth device that are within that range and when you see the name of your bluetooth device appear on the screen press next.
    Enter the bluetooth device passcode,this can be found in the device owners manual.if the passcode is accepted then press done.The pairing process between your HTC phone and a bluetooth device is complete.
    BEST OF LUCK
    Jul 06, 2010 • Cell Phones
    1helpful
    Pairing with a motorola bluetooth device
    Hello, Barb.
    Here are some instructions from the manual:
    To set up a Bluetooth connection, do the following:
    1. Select Menu > Settings >
    Connectivity > Bluetooth.
    2. To activate or deactivate the Bluetooth function, select
    Bluetooth > On or Off.
    Indicates an active Bluetooth connection.
    3. To search for compatible Bluetooth audio devices, select
    Search for audio enhancements and the device that you want to connect to the phone.
    To search for any Bluetooth device in range, select Paired
    devices. Select New to list any Bluetooth device in range.
    Scroll to a device, and select Pair.
    4. Enter the Bluetooth passcode of the device to associate (pair)
    the device to your phone. You must only give this passcode when you connect to the device for the first time. Your phone connects to the device, and you can start data transfer.
    Hope this helps.
    4helpful
    I need a passcode for my motorola bluetooth h505 to pair with new phone
    2answers
    How do you connect bluetooth to a sony ericsson k610
    let phone in menu /settings searts for bluthooth device and the device like for earpusch on buton the same time device phone wil see it select connect and put code in 0000 and device are connect
    if you want connect to pc you need first bluethooth device on pc like usb blue thooth stick and on pc you need software this are for free from itv bluesoleil google for it and also syngr software from microsoft.
    I switched from Sprint to At&T, and the bluetooth worked for my Sprint phone, I'm currently installing it into my AT&T phone and it has found the device. On the side of the bluetooth itself the...
    M540
    To pair your phone with another Bluetooth device:
    1. Select (home) and press (Menu/OK) > Tools > Bluetooth >
    Add a New....
    2. Select a device category and press (Menu/OK). (Your
    phone will display a list of discovered in-range
    Bluetooth devices.)
     Select from: Headset/Car Kits, All, Phone, PC, or
    Printer.
    3. Select a device and press (Menu/OK). Select Info (right
    softkey) to obtain more information about the
    device prior to pairing.
    4. Enter the passkey and press (Menu/OK).
    5. Enter a unique Device Name and press Done (left
    softkey).
    Please rate this answer
    2helpful
    Pairing a moto bt h505 to a metropcs samsung sch-r410 cell phone
    Try typing in 0000 four zeros that should be the default passcode unless someone has changed it
    Dec 13, 2008 • Cell Phones
    Top Motorola Mobility Radio Communications Experts
    ADMIN Eric
    ADMIN Eric
    ADMIN Andrew
    ADMIN Andrew
    Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
