No such code for this machine
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
SOURCE: ERROR OF C-F024
Sir,
have you replaced the image unit recently.Mite need a new Image Unit. Try turning off then on the machine, to clear the code first.
SOURCE: my minolta dialta copier has
COF24 is an AIDC code. The AIDC sensor is under the drum and is likely dirty. Remove drum unit, remove drum and wipe sensor. If there is a pile of toner you will probably have to replace the anti-spill blade
