Canon PowerShot SX10 IS Digital Camera Logo
Anonymous Posted on May 28, 2009
See dust or drop of water on my pic canon sx10 is
I have problem in my canon sx10 is (fixed lens) i see Dust inside lens or Drop of water on my photo , so how i can clean my lens (from inside) please help me
Anonymous
Level 2:
Novelist:
  • Expert 164 Answers
  • Posted on Jul 25, 2009
Anonymous
Expert
Level 2:
Novelist:
Answers
164
Questions
0
Helped
50488
Points
222
You have to disassembly your camera for it, including the lens assembly.
Even if you have experience and skills in fixing electronic devices, I don't recommend it, since any particle of dust will get inside the lens and your camera, and will affect it.
The recommended place to perfom such cleaning activity is a Clean room (class 3 or higher), and have handy the proper cleaning tools.
Disassembling the lens is tricky and also needs a lot of patience and technique skills to do it properly.
Imagine that by accident a spring pops up a tiny metal ball (1.5 mm diameter) and you lose it in your home, then because of it, your lens will not work properly.
If it has warranty, I do recommend you to send it to cleainig to a professional repair and cleaning service.
If still you have questions or doubts, or need a cheaper quote for it (after get some quotes from local repair centers for comparison), you can contact the ebay seller Great_items_2004
Best regards,
Testimonial: "THANK YOU"
2answers
My Canon PowerShot SX10 IS is 2 years old. Now, when I use the zoom, it beeps continuously and turns off, but the power button glows as the camera is on. Then I need to switch off the power button and...
hi, that problem mostly from dust on lens. Cleanup the lens using soft material such cloth, tisue etc, on telescopic lens (silinder which deliver lens forward un reverse).
good luck.
When turning on camera "lens error, restart camera" displays on screne
Problem: dust in the gaps near lens which makes it jammed. Effect: the sceen shows blk color. Solution: just blow over it or vaccum it.
Lcd display will not work on canon power shot sx10 is - camera will take pictures and i can review pics on the lcd display but will not show any pictures when trying to take photos. it started this problem...
Of course! You mentioned the beach so maybe salty water or sand got inside the camera. (Salt can interfere with the electrical connections inside the camera and possibly short-circuit.) Send it back for repair to replace any damaged parts you may need. They'll send it back good as new :)
1helpful
How do I clean dust inside the camera? I noticed some splotches on my photos, then looked closely at the lens and it appears there is dust on the inside of the lens.
You can't clean inside the camera. Dust inside the lens would be so out of focus, it wouldn't register on your pics unless the particle was huge. Do these splotches only happen in your flash pictures?
Remove dust ccd ixus 75
Do these "stains" only appear on flash pics? Are they always in different places on each pic? If so, these are dust particles reflecting the flash back to the lens.
Dust behind lens
If the dust is inside the lens, then you are unlucky. Canon lenses (except for a select number of the L series lenses) are not dust or weather sealed. So each time you work the zoom mechanism on a inexpensive EF 75-300mm f/4-5.6 III lens, the mechanism is working like a giant billows allowing air (and dust and moisture) to flow through the lens and camera body. Sometimes large dust particles can accumulate on the different lens elements, but it does not have any impact on the quality of the photo
If the dust is creating problem fro your picture get it fixed from service center i will suggest you should not try to open it
Regards
Lens error. restart the camera
Did you drop your camera? the lens mechanism might be jammed,Did you brought it from the beach? It might have some dust or sand particles inside the lens. Have You changed the batteries? It can also be caused by poor battery.Please recharge battery or change new alkaline batteries. this website might also help you.
3answers
Error message E18
at my A80 the following Link solved my problem properly.
http://photography-on-the.net/forum/showthread.php?t=5700
Best greets
Martin
2helpful
How To Remove The Fixed Lens From The Olympus E-10 For Cleaning
The easy fix is to buy a new camera. Or trade up to Canon equipment that is easier to clean.
-BLL63
3helpful
2answers
Canon SD600 lens jam
I followed the directions contained in http://www.avh.dds.nl/Fix-Canon-SD600-Lens-Error/ and by disassembling the camera and turning the rotor just a little bit (page 4 of the instructions), it freed up the lens and it is now working perfectly! The camera had been put down on the lens as the lens was retracting and I assume that jammed the retract mechanism. While the camera was open, I blew out whatever dust/dirt was there (didn't see much). The fix took me probably 20-30 minutes, and I am very pleased with myself!
Top Canon Cameras Experts
old marine
old marine
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Canon Camera Expert? Answer questions, earn points and help others
