Technically, an Error 404 is a client-side error, implying that the error is your mistake, either because you typed the URL in wrong or the page has been moved or removed from the website and you should have known. Try another URL or check with the site your are trying to contact to see if they are still active. Hope this helps.
Mine works fine- here are my settings on thePrada (multimedia settings for messages)
T-Mo MMS as connection Proxy port is 9201 Proxy IP is 216.155.165.50 Internet mode is WAP Profile name is T-Mo MMS MMSC is http://216.155.174.84/servlets/mms
Usually an error 404 is an Internet site not found. This can be caused by not having an Internet connection. Check to make sure that your Internet connection is working and try another site.
The Error 404 "Page not found" is the error page displayed whenever someone asks for a page that's simply not available on your site. The reason for this is that there may be a link on your site that was wrong or the page might have been recently removed from the site. As there is no web page to display, the web server sends a page that simply says "404 Page not found".The 404 error message is an HTTP (Hypertext Transfer Protocol) standard status code. This "Not Found" response code indicates that although the client could communicate to the server, the server could not find what was requested or it was configured not to fulfill the request. The 404 "Not Found" error is not the same as the "Server Not Found" error which you see whenever a connection to the destination server could not be established at all.
A 404 error is an HTTP status code that means that the page you were trying to reach on a website couldn't be found on their server.
No matter the reason for the 404 error, there is plenty you can do to try to get to that page you were after:
How To Fix the 404 Not Found Error
Retry the web page by clicking the refresh/reload button or trying the URL from the address bar again. The 404 Not Found error has been known to appear on occasion even if there is no real issue so a simple refresh will often load the page you were looking for.
Check for errors in the URL. Often times the 404 Not Found error appears because the URL was typed wrong or the link that was clicked on points to the wrong URL.
Move up one directory level at a time in the URL until you find something. For example, if www.w.com/a/b/c.htm gave you the 404 Not Found error, move up to www.w.com/a/b/. If you get nothing here, move up to www.w.com/a/. This should lead you toward what you're looking for or at least confirm that it's no longer available.
The 404 or Not Found error message is a HTTP standard response code indicating that the client was able to communicate with the server, but the server could not find what was requested.
The web site hosting server will typically generate "404 - Not Found" web page, when users attempts to follow a broken or dead link, hence the 404 error is one of the most recognizable errors users can find on the web.
A 404 error should not be confused with "server not found" or similar errors, in which a connection to the destination server could not be made at all. A 404 error indicates that the requested resource may be available again in the future; however, the fact does not guarantee the same content.
Try to play another video if that shows 404 error so it means there is some problem in your internet connection. And if the video play so it means the video whcih you want to play before and showing 404 error is removed by the copyright rules violation on you tube.
The 404 or Not Founderror message is a HTTPstandard response code indicating that the client
what was requested. 404 errors should not be confused with "server
requested resource may be available again in the future.
someone asks for a page that’s simply not available on your site. The
request.
request.
