Connected to denon amplifier but low sound
SOURCE: Just set up new turntable AT-PL50. Sound very distorted
Your query incomplete. Please resumit.
SOURCE: volume is low on my turntable
You have to amplify the output from your turntable output to the input of your amplifier. To do this you can buy what is known as a pre-amp. Radio shack probably still sells them.
Be sure to ground your turntable to your amplifier and not the pre-amp. This should stop any hum or at least diminish it. Bear in mind that your records will not sound as loud as your CD's. Hope this helps.
SOURCE: problems connecting turntable to amplifier
I hope you have it connected to the Phono input on the left rear of the receiver. Otherwise the minute signal generated by the phono cartridge is too small for the other inputs to process.
The buzzing noise/bad channel is probably a bad connection in the tonearm/headshell connection or one of the 4 wires attaching the cartridge to the shell. If you DON'T want to blow up your speakers, TURN YOUR RECEIVER OFF, turn the volume to 0 or select another input before messing around with the tonearm.
Swap the two channels from the tonearm to the Phono connectors to prove the buzzing is external (at the turntable). I think the Dual CS415 uses the old standard headshell. With the volume down flip the lever toward the back, carefully remove the assembly and look over the tiny multi-colored wires with the brass crimp-on ends. We're looking for tight kinks or broken wires. Then put it back. maybe reseat it a few times to wear off any oxidation and try it again.
SOURCE: sound coming from speakers is very low.Turntable
if there is no phono input on your home theatre amp, plug the turntable into the auxillary sockets and not the sat/tv/cd input as it wont work properly in that socket. if after putting the turntable into the auxillary socket it is still too quiet then you should purchase a specially made small pre-amp booster amplifier designed for turntables to inprove the signal to noise ratio from a reputable hi-fi shop/dealer. good luck
SOURCE: very low signal from the turntable to the
Phono cartridges need PRE-amplification. If your electronics does NOT have a specific PHONO input, you need to get a PHONO preamp to pre-shape and step the signal up to Line Level.
Testimonial: "Many thanks you helped me to clear years of uncertaninty"
