11 - Cylinder Identification Sensor
14 - Intake Air Pressure Sensor (Pipe System)
15 - Throttle Position Sensor (for Throttle Valves)
20 - Intake Air Pressure Sensor / Atmospheric Pressure Sensor
from what ive had in the past
your issue is with the first of the fault codes
check your engine wiring harness with a bright light or torch around the fan or fan housing by the radiator
look for nicked or cracked wiring
the sensor wire has a tendency to get nicked by the fan
but you can repair or replace
please see pics
pic (1) nicked Cylinder Identification Sensor wire
pic (2) repair with connection blocks or solder together
pic (3) wrap with insulation tape after repair
once you have done the repair
try to reroute the wire away from the fan and housing
if that fails get a new sensor
have fun
