Everything works on the unit except that the claw will not move down. Can this be fixed?
Yes it can be fixed, you have to go into the settings of the claw machine and adjust the strength of it. https://www.clawsomesingapore.com/ has a tutorial of how to do it.
Check for voltage at the motor power in leads. If missing problem goes back to controller brd or power supply.
If present your motor is bad or string is jammed.
Post the model # and manufacturer...it helps tech,s big time when you do.
