Powermatic 66 10" 3 HP 1 Phase 230V Table Saw w/ 30" Accu-Fence & Rout-R-Lift 1660806K Logo
B
Bob Brey Posted on Jan 14, 2014
Align blade Cannot get blade to 90deg. Closest to 90 deg is 91.6 deg
jtritz
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Apr 03, 2014
jtritz
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
80
Points
Bob,
I just bought one of these saws 2 weeks ago (1997 Model) I have it completely disassembled as of right now. There is a worm gear that drives a very large set of teeth attached to the trunion. Mine were completely clogged and full of crud that the mechanisim would barely turn. I am thinking the teeth on the worm gear or trunion at the 90 degree end need to be cleaned to allow it to hit its full range of motion, Its also possible the teeth on one of these pieces is cracked or broken. I would try cleaning them. If you cant get to them, the cast iron top comes off fairly easily. # bolts hold the right wing to the main top and 3 bolts hold the main top to the cabinet. Of course if you have rails, these need to come off first. I have attached images of the before and after of cleaning these parts so you can see if they are really bad like mine, it could be your problem, Hope this helps Align blade - de3088fd-0aec-4075-8706-9fa0612a5ce0.jpg
Can this saw be adjusted if it cuts out of square? And if so, how.
Hello, yes this saw can be adjusted.
To calibrate the table, use a framing square up against the rear fence and see how the blade tracks. To adjust this: loosen the bolts holding the rear fence down and move the fence until it is square with the blade track and tighten.
To adjust the bevel: use a speed square to check for 90deg and 45deg on the blade. Using the 13mm bolts found at the pivot point on the trunnion you can adjust the 90 and 45 degree angles.
6helpful
2answers
I have a 1998 Holden Astra eng noEL20B24119 and want to know the Head bolt torque settings and sequence. The engine is the transition model with twin tappet cover seals. has the torx star headed bolts.
I cannot find a EL20B in my data,but all Astra listed had the same head sequence as shown:
10 6 2 3 7
9 5 1 4 8
the torque specs for the C20XE,C20NE,X20XEV were all
25nm(18lb/ft),-then 90 deg,-90deg,-90deg.
Z20LET were as above plus an additional 15deg.
Same data for smaller and larger engines(except a couple that were 45deg instead of 15)
Make sure that you replace the head bolts with new,they are torque to yield bolts that are designed to stretch to 'plastic' state,and should not be reused.
Put grease(graphite if you have it) under bolt heads and washers,oil the threads.
Usually the head sets come with the torque specs.
I hope this helps you.
How do you change out water filter?
Hi and welcome to FixYa, I am Kelly
Press in hard.. rotate it 90 degrees Counter clockwise and wiggle / pull it out. When you re-install a new filter align the filter with the internal locking tabs and press in hard and rotate 90 degrees clockwise.
Some times the filter can br really fussy to remove you just have to keep wiggling and pulling to get it out of the recepticle once you have rotated it 90 Deg CCW.
Thanks for choosing FixYa,
Kelly
1helpful
Is it canon laser LBP 3300 printer take Legal Size printing ?
Here are "little" specification:
Body installation method desktop page printer
Photosensitive medium OPC drum
Exposure method semiconductor laser
Development method Toner projection development
Transfer method by roller
Separation method by curvature
Cassette pickup method by pad
Multifeeder pickup method by pad
Drum cleaning method by blade
Fixing method on-demand
Delivery method face-down/face-up
Toner supply type by toner cartridge
about 6000 prints (A4, single-sided; at 5% image ratio)
Warm-up time in standby: 0 sec (at power-on: 10 sec or less)
Print area top: 5 mm; bottom: 5 mm; left/right: 5 mm (if envelope, top, bottom, left,
right: 10 mm)
Printing resolution 600dpi
First print time 9 sec or less (approx.; A4)
Print speed (A4) 21 pages/min (approx.)
Cassette paper size A4, B5, A5, Legal, Letter, Executive
Multi-purpose paper size A4, B5, A5, Legal, Letter, Executive, Envelope DL, Envelope COM10,
Envelope C5, Envelope Monarch, Index Card, Custom Paper Size (width
76.2 to 215.9 mm, length 127.0 to 355.6 mm)
Cassette paper type plain paper (64 to 90 g/m2), heavy paper (91 to 120 g/m2), recycled
Multi-purpose paper type plain paper (64 to 90 g/m2), heavy paper (91 to 163 g/m2), recycled
paper, transparency, label paper, envelop (DL, COM10, C5, Monarch,
B5)
Cassette capacity 250 sheets (approx.; plain paper, 64 g/m2)
Multi-purpose capacity 1 sheet
Delivery tray stack 65sheets (Face-down) /1sheet(Face-up Output Slot)
Memory 8 MB (internal; no optional memory available)
Operating environment
(Temperature range) 10 to 32.5 deg C
(Humidity range) 20% to 80% RH
Noise 52.8 dB or less (during printing; based on ISO9296; announced noise
emission)
Power supply rating AC100V±10% (50/60Hz ±2Hz)
Power consumption (Maximum) 790W or less (approx.; 20 deg C; for input of rated power supply;
including peak value lasting 1 sec or more)
Dimensions 370 (W) x 375 (D) x 258 (H)mm
Weight printer: Approx;11kg; toner cartridge: Approx,0.8kg(2.5K)
Option paper feeder
How do i get the blade out of my gst 2000
pull up knob on top at front turn anti clockwise three times turn blade 90 deg remove blade insert new blade turn 90 deg turn knob on top clock wise untill clicks press knob back down you are ready to go
Jun 04, 2010 • Bosch Saws
When I try to cut a 45 it seems to be cutting a little more than a 45. how do I adjust it?
Make sure the blade is 90 deg vertical to the saw table. Make sure the indicator is set approprately. Raise the blade just enough to clear the table/base. Place a swanson speed square against the fence and blade. Make sure the indicator is at 90 degrees. Here you might want to tilt the square and check that the complete blade is flush against the sqaure as high up as possible. Lay the square back flat on the table and pull the blade toward you as much as possible. The teeth on the blade should ride against the square extented completely out.
Now set the square against the fence with the 45 degree angle coming away from the table and set the blade on the 45 deg mark on the insicator scale.
The blade should touch the square all the way out fully extented.
Or just experiment with some scrap and check
2005 silverado extended cab, 2 wd, 2 part drive shaft. Marked relationship of drive shaft to differential, transmission. Had shop replace u-joints, marks got removed. I reinstalled with what markings I...
Well on a one piece shaft they are 90Deg so I would guess 90Deg on a two piece.If they are facing the same way it would be like turning a jump rope.All weight swings to the same side at the same time,rather than being off set.I usualy have it balanced at the same time as I replace the U-Joints.Well just my two cents.Hope it helps and good luck.
1helpful
My hotpoint aqualtis washing machine has started to smell following a wash cycle of domestic cleaning cloths. It completes a normal cycle. I have also checked the filter at the front and it is clear. Any...
Hi
Every 30 days is a good idea to use the 90deg wash cycle with just a towel in it with no detergents or use the descaling products available in the market with the 90 Deg hotwash. This problem also happens when always cold wash is used as detergent only really disolve well when the temp is 26 deg c or more.
There could also be mould in the machine which can be found round the bellow seals. IF it is present normally like dark spots and minor then they can be cleaned with methyl alcohol but if it is too many then the seal needs to be replaced. ALso after a wash wipe down the bellow seal with a dry cloth and keep the door slightly open for the internals to vent and dry.
Hope this helps.
Reynold
11helpful
2answers
Changing the blade on my Bosch GST 2000
lift knob on top twist 3 times anti clockwise remove blade by twisting it 90 deg insert new blade turn 90 deg,turn knob on top clockwise until it clicks press down and you are ready to go
12" craftsman table saw 0 to 45 deg adjustment gears striped
Sears has a site for parts and owner manuals at www.ManageMyHome.com.
It could be something is just loose and out of adjustment so that the teeth were able to slip on the gear. But I've never had a look at one of those to say for sure...oil always helps these things move easier...
Apr 19, 2009 • Saws
Top Powermatic Saws Experts
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Marty Warge
Are you a Powermatic Saw Expert? Answer questions, earn points and help others
