When turned on programmed and started. It fills with a little bit of water the drum does not turn, it empties and displays F11 fault notice. I have f11 coming up on the programmer.
To Clear F11 Code after a power cut.
1, Power off at the machine. Do the next 4 steps within 3 seconds.
2, Press Temperature Button in.
3, Power on
4, Release temperature button
5, press Soil Type button
You will now hear the door lock release so you can get to your pants.
Diagnostic
code is now displayed. You can switch the washer off and back on and
the error code is clear. If you do this it will work.
Thanks for using Fixya.
usually the bridge rectifier on the powerboard causes this problem, its a square component soldered to the board near the fuse that converts A/C to D/C. I've repaired 3 dysons with F11 faults by replacing this component and the fuse.
hi, ive got the same fault but not sure its the fuse as the drum turns a few times pumps runs and drains etc, i remember from previous issue the fuse is a pain to get to so is it worth the hassle if all else is turning , running etc ?
SOURCE: how to repair a F 11 fault on a DYSON CR01 flow check
3, Power on
Diagnostic code is now displayed. You can switch the washer off and back on and the error code is clear. If you do this it will work.
f11 fault code is a problem with the main power board (could be blown fuse) or a blown board check the fuse the board is behind the back plate in the bottem right corner (looking from the back of the machine.(!unplug before you take apart!)
It is possible that the machine does not start off the cycle because there are errors or back feedback from the inputs. For the program to start up the main program controller must initiate the INLET valve to open up and allow water to flow into. If this does not happen then the voltage at the inlet valve must be checked or the fault relates to no voltage from the controller. This means the controller is a suspect.
If the water flows then the flow should be good, if not the inlet valve is bad or there is dirt in the filter. Also check the flow at the inlet of the water line. Once the water comes into the system the WATER LEVEL SENSOR - normally a pressure switch- must activate at the preset/chosen level to give the signal to the program controller to switch on the motor. What is most important for the motor to start functioning is that the door switch must be ON when the door is shut or this will be an error for starting the motor for rinse and wash.
Finally after the wash the drain valve will be activated, the water is allowed to come in to rinse and then finally the dry spin with the drain valve/pump activated so as to drain off all the water from the clothes during the spin.
Make sure that a fault in any of the cycle will relate to the specified action, so check the command from the program module and then the executing device be it the valve or motor or pump.
